Finding the Magnetic Field of a Point Charge Using Biot-Savart Law
The discussion revolves around finding the magnetic field of a point charge using the Biot-Savart Law. Participants are exploring the application of the law in the context of a point charge and a circular wire, questioning the integration bounds and the meaning of infinitesimal elements in the equation.
  • Participants are attempting to solve for the magnetic field but express uncertainty about the integration bounds and the definition of the infinitesimal element, ds. There are discussions about the correct formulation of the Biot-Savart Law and the implications of integrating different elements.
Some participants have provided guidance on the nature of the integrand and the significance of the angles involved in the problem. There is an ongoing exploration of the relationships between the variables and the geometry of the setup, with no explicit consensus reached yet.
Participants are navigating the complexities of integrating vector quantities and the implications of the geometry of the problem, including the changing angles as the charge moves. There is a focus on ensuring clarity in the definitions and roles of the variables involved.
Tomi Kolawole
[/B]
I soled for the integral of the magnetic field but i don't know what bounds to intergrate over and also i what is DS in this case? its a point charge so shouldn't bio savart have q(v*b) instead of i(ds*r)?[/B]
Tomi Kolawole said:
I solved for the integral of the magnetic field but i don't know what bounds to intergrate over and also i what is DS in this case? its a point charge so shouldn't bio savart have q(v*b) instead of i(ds*r)?[/B]
It's not clear what you've done. You say you solved the integral of the magnetic field, but you later say you don't know what goes into it. Please show your actual work instead of just describing it.
Can you explain why the point charge experiences a force? And what is the Biot-Savart law used for here? If you can answer those questions, you should be able to figure out the answer to your last question. And you really need to know the answer to those questions to solve the problem.
i solved for the magnetic field and got (u*i*DS*R)/(4*pi*(R^2+D^2)^(3/2)).Is the DS=2piR? if it is my problem is solved but i don't know why it would be 2*PI*R. with R being the radius of my circular wire.
##d\vec{s}## is an infinitesimal quantity. Is that what you mean by DS?
yes sir that's what i meant isn't that the length of the wire? so will that be 2*pi*R?
The formula of bio savart has (i*ds x r)/r^3 . <<<<<That is the DS i am referring to sir
The wire isn't infinitesimal, so no, ##d\vec{s}## isn't the length of the wire. If you were to integrate ##ds = \| d\vec{s} \|##, then you'd get ##s##, which would be the length of the wire. Note that ##d\vec{s}##, ##ds##, and ##s## aren't interchangeable. They mean different things.
Back up for a second. Remember the integrand of the Biot-Savart law is a vector, so you have to add vector-wise all the infinitesimal contributions to the magnetic field at the location of the charge. What happens when you do that and integrate around the entire ring? What components will be in the final sum?
if i integrate ds, which is each infinitesmal length of the wire, i should get the circumference no? which is 2*PI*R the length of the wire
Yes, that's what I said in my previous post. But integrating ##d\vec{s}## and integrating ##ds## isn't the same thing. One is a vector while the other is the length of the vector. Integrating ##d\vec{s}## around the ring would give you 0, the displacement between the starting and ending points, but integrating ##ds## would give you ##2\pi R##, the distance around the path.
Anyway, I'm asking you to back up because your integrand is incorrect. You can't simply ignore the cross product in the integrand.
my cross product was (dsxr) and because its bcross product the solution is ds*rsin(theta). and then i converted all my variables into units of length through pythagoran theorem.So r^2 became (D^2+R^2) and sin(thetha) became R/(d^2+r^2)^(1/2) that's how i evaluated my cross product? Can you tell me what was wrong with my approach sir
##\theta## is the angle between ##d\vec{s}## and ##\vec{r}##, the vector connecting the infinitesimal piece of the ring to the point where the charge is, right? Isn't the angle between them ##90^\circ##?
that may be the case but since i converted my sin(theta) to its compenent opp/hypotenus which is R/r =R/(D^2+R^2) wouldn't that account for whatever theta might be? even if its 90 degrees? i only converted my variables to make integration easier because r changes as the particle moves.
I think because the angle at which The charged particle will be at a certain time changes because the particle is constantly moving upwards with velocity v*. so wouldn't it be unwise to assume the angle between them is 90 if its constantly changing sir?
I was mistaken. Your integrand is correct, but you apparently stumbled onto the right one accidentally because your reasoning to get it is incorrect. ##\sin 90^\circ=1## and is clearly not equal to ##R/r##.
There are two angles in this problem (in calculating the magnetic field at the location of the charge). One is the angle ##d\vec{B}## makes with the the horizontal axis. Let's call that ##\phi##. And then there's the angle between ##d\vec{s}## and ##\vec{r}##, which you called ##\theta## and which is ##90^\circ##. So ##\| d\vec{s} \times \vec{r} \| = \| d\vec{s} \| \| \vec{r} \| \sin\theta = ds\,r##.
Now when you integrate ##d\vec{B}##, only the horizontal component, ##dB_z = dB \cos\phi##, survives. You should be able to explain why this is the case. And ##\cos\phi = R/\sqrt{R^2+D^2}##, which, again, you should be able to convince yourself is correct.
Which direction is the B pointing in? i assume you use right hand rule for this? your solution makes a lot of sense now
Yeah, use the right-hand rule to determine the direction of ##d\vec{B}##. It's going to rotate as you go around the ring.
  • · Replies 18 ·
10K
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 17 ·
