Finding the Magnitude of a Dipole Moment
The discussion focuses on calculating the magnitude of an electric dipole moment (p) in a uniform electric field (E) of 40 N/C. The torque (τ) on the dipole is described by the equation τ = -pE sin(θ), where θ is the angle between the electric field and the dipole moment. The maximum torque occurs at θ = 90 degrees, leading to the conclusion that the magnitude of p can be derived from the maximum torque value, which is not explicitly provided in the discussion but is critical for solving the problem.
  • Understanding of electric dipoles and their behavior in electric fields
  • Familiarity with torque equations in physics
  • Knowledge of trigonometric functions, specifically sine
  • Basic calculus concepts related to maxima and minima
  • Study the relationship between torque and electric dipoles in detail
  • Learn how to derive the maximum and minimum values of trigonometric functions
  • Explore the implications of torque in various physical systems
  • Review the concept of electric fields and their effects on charged particles
Students studying physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to electric dipoles and torque calculations.
jendead
[SOLVED] Finding the Magnitude of a Dipole Moment
Hi there,
I'm new to posting, but I've used this forum many times to help me with my homework :) I went the "take a photo of the textbook" route (there is a picture with the problem), so I hope that's acceptable.
A certain electric dipole is placed in a uniform electric field E of magnitude 40 N/C. Figure 22-51 gives the magnitude (t) of the torque on the dipole versus the angle (theta) between field E and the dipole moment p. What is the magnitude of p?
E = 40 N/C
(t) = -pEsin(theta)
The hint we were given was "When is the torque minimum, and when is it maximum?"
I'm not sure where to start. The textbook and my lecture notes aren't helping me at all.
I don't quite understand the given figure, or what is being counted on the y-axis (I think that number on the left is multiplied by 10^-28?). I assume that somehow I am supposed to use the min/max torque, set them equal to each other, and solve for p.. but I don't know how I'm supposed to find the min/max angles in order to do this.
edit: Apparently file attachments don't work..
http://www.clan-dm.net/members/jen/dipolequestion.jpg
The minimum torque will be when sin theta is equal to zero. The maximum will be when sin theta is equal to one. Yes, the y-axis is multiplied by 10-28. Since the minimum torque is zero i would suggest using the maximum torque.
Ok, that makes sense now. For some reason max torque being at 90 degrees was completely glossed over in class. In retrospect it does seem obvious now, but when I'm learning new stuff I become confused very easily.. especially when my last calc class was over a year ago.
Thank you very much. I'm sure I'll be back, because this semester is already killing me. :)
No problem. P.s. Welcome to the forums. :smile:
Thank you! I only wish I thought of registering sooner. :)
  • · Replies 25 ·
  • · Replies 30 ·
