Finding the magnitude of the friction force.
The problem involves calculating the frictional force acting on an 8kg ball moving down a 12m high inclined plane, with given initial and final speeds. The inclined plane is set at an angle of 30 degrees to the ground.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of potential and kinetic energy, with some questioning the inclusion of initial kinetic energy in the energy balance. There is also a focus on clarifying the initial conditions of the ball's motion.
The discussion is ongoing, with participants providing insights into the initial conditions and energy calculations. Some guidance has been offered regarding the importance of considering initial kinetic energy, leading to a revised understanding of the problem.
Participants note potential confusion regarding the initial speed of the ball and its implications for energy calculations. There is an acknowledgment of differing interpretations of the problem setup.
Ripe
An 8kg ball moves down a 12m high inclined plane with a speed of 6m/s. By the time it reaches the bottom, the speed is measured to be 12m/s. What is the frictional force opposing the motion? The inclined plane has an angle of 30 degrees with respect to the ground.
Potential energy = mgh
Kinetic energy = 1/2mv^2
Work done by external forces = ΔE
Work done: Fs (or Fscos(theta))
The first step is to calculate the potential energy and kinetic energy, which is 960J and 576J respectively. Hence ΔE=960-576=384J.
Now, since the height is 12m and the angle is 30 degrees, the length of the inclined plane is 12/sin30 or 24m.
Finally, 24f=384 which yields an answer for f as 16N.
I might have gotten the correct answer, but in the book it says that the answer is supposed to be 22N, so I'm assuming I'm missing something, perhaps it has something to do with the initial speed which I haven't included in my calculations.
Thanks in advance,
I think you forget initial KE.
Please elaborate. I assumed it was 0.
I'd very much like help on this one!
A bit unclear on the wording, but the initial speed is 6 m/s at the top of the ramp. Watch your signage.
Not sure If I follow what you're saying. Could you elaborate?
l think the problem meant to say that the ball is projected down the ramp with an initial speed of 6 m/s, that is, it already had a speed of 6 m/s when it reached the top of the ramp. So re-do your calcs, and see azizlwl post 2.
It doesn't travel up the plane, it travels down the plane. I.e. it has an initial speed of 6m/s when it is at the top (the beginning) and a speed of 12m/s at the bottom (the end). Hence, initial KE=0?
EDIT: Oh! Now I see what you mean. It didn't go from rest to 12m/s meaning it had some kinetic energy at the top as well. In other words, initial KE=144J and hence, initial (total) energy= 144+960=1104J.
Using that, I get an answer of 22N. Thank you for your help!
  • · Replies 20 ·
  • · Replies 19 ·
11K
