Finding the members of the Lie algebra of SO (n)
The discussion focuses on proving that the members of the Lie algebra of SO(n) are anti-symmetric nxn matrices. The approach involves differentiating the equation R.RT = I with respect to a parameter t and evaluating the result at t=0, where R(0) is the identity matrix. Participants emphasize using the product rule for differentiation and understanding that a matrix A is anti-symmetric if A = -A^T. One user expresses initial confusion but ultimately resolves the problem independently. The thread highlights the importance of engaging with the material and seeking guidance rather than expecting direct solutions.
c3po
Show that the members of the Lie algebra of SO(n) are anti-symmetric nxn matrices. To start, assume that the nxn orthogonal matrix R which is an element of SO(n) depends on a single parameter t. Then differentiate the expression:
R.RT= I
with respect to the parameter t, keeping in mind that I is a constant matrix. Then you must consider that the element M of the Lie algebra is defined as:
M = (dR/dt) t=0
And that R(0) is the identity matrix.
(A.B)T = B T.A T
d/dt[R(t).RT(t)] = 0
I was introduced to linear algebra and group theory very recently and am having trouble doing any of the proofs that I am assigned for homework. I feel that this problem is probably easy, but it is surely not coming to me easily at all. . .
Please help!
I figured this out for the case of a 2x2 rotational matrix, but how would I generalize this for nxn matrices?
R.RT= I
M = (dR/dt) t=0
(A.B)T = B T.A T
Please help!
Use the product rule. Evaluate at ##t=0##. Remember a matrix ##A## being antisymmetric means ##A=(-A^T)##. You want to show ##R'(0)## is antisymmetric.
Can you please provide complete solution? I have same question
No, that's not something we do. Try it and post your work if you want guidance. This isn't even hard if you give it some thought.
Thanks. I solved it :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 19 ·
  • · Replies 24 ·
