Finding the Moment of Point B: Is it Largest?
  • Thread starter Thread starter freshbox
    Moment Point
The discussion revolves around calculating the moments at points A, B, and C of a beam under various loads, with a focus on determining which point has the largest moment. The original poster expresses confusion over their calculations and the results presented in their textbook.
  • Participants discuss the calculations for moments at different points, questioning the correctness of the original poster's methods and the sign conventions used. There are inquiries about the necessity of drawing free-body diagrams and the implications of moment signs.
Several participants have provided guidance on the importance of consistent sign conventions and the use of free-body diagrams. There is an ongoing exploration of the calculations and interpretations of the moments, with no clear consensus on the correct approach yet.
Participants note the complexity of the problem, including the need for clarity on the definitions of moments and the effects of different sign conventions. The original poster's calculations are questioned, and there is a suggestion to refer to bending moment diagrams for better understanding.
freshbox
Hi can anybody tell me if my working for finding the moment of a b c is correct?
Taking clockwise as +ve
Ma+1.2k x 3 +0.7 x 7 = 0
Ma= -8.5Knm
Mb-8.5+1.9k x 3=0
Mb=2.8kNm
Mc=1.2k x 4 +1.9k x 7 -8.5k=0
Mc=-117.85Nm
Hence Point B has the biggest moment am I right? However the book says is Point A. Please advice, thank you.
What is the full question?I don't understand what you are trying to do.Find the largest moment?
Ma= -8.5Knm
Can you explain to me why my working is wrong for Moment A, thank you.
This is the real question. For flexture stress to be maximum at the point, the value of "M' must be largest in the beam
Ma= -8.5Knm
Isn't that the total moment??
It's also wrong.
M=F*perpendicular distance.
M=1.2k x 3 + 0.7 x 7
=8.5KNm
Why -8.5kNm?
If clockwise is +,and all the forces are acting on clockwise direction,Why should there be any negative value?
EDIT:That tensile flexural state thing is beyond my knowledge:eek:.Maybe someone else can help you from here onwards. Sorry :frown:
Ma+8.5=0
Ma=-8.5
I put a = 0 behind my equation and I switched it over, hence I got a negative 8.5
Formula for question
:cry:
All my 3 moments are wrong? :cry::cry::cry:
Moment about A is correct...what does the minus sign mean?
I have no idea what you are doing when summing moments about B and C. The moment at A is an external reaction moment. Elsewhere , moments ate internal in the beam and can be calculated using free body diagrams or shear and moment diagrams.
EDIT: o I think I see now what you are doing...you are messing up your plus and minus signs. These moments are more easily calculated using right hand sections.
For my moment about A my minus means that it is -8.5Nm CCW
whereas for moment B and C, let's start with B, I am trying to take the FBD LHS.
I have attached a picture showing the example of what I am trying to do. The question in this picture is different. I am actually "copying" the steps to help me solve my #1 problem.
I am confused right now :cry::cry:
How I work out C post #1 is based on this question.Taking clockwise as +ve
Ma-5k x 1.2 = 0
Ma=-6kN CCW
Mb+5 x1.2 -6k =0 (I added -6kN which is Moment A into this equation)
Mb =0
So for post #1 working
Mc=1.2k x 4 +1.9k x 7 -8.5k=0 (I added the -8.5k Moment A which I found earlier into this equation)
Mc=-117.85Nm
You are hopelessly confusing yourself by first not drawing a free-body diagram of your beam. Currently, you are just calculating random moments, adding or subtracting them at will, and hoping you get the right answer somehow.
Draw the FBD of the cantilever and find the reacting force and moment at A. If you can do that, then further help will be forthcoming. Right now, you are just spinning your wheels, and mixing these other problems in with the original problem is not helpful.
I refer to other example because I tried to solve the problem as I study alone and have nobody to ask :cry:
This is my working.. All moment I got are the same. So referring to post #4, which point has the largest moment?
That's just the point. If you follow the hint given in the problem and draw the bending moment diagram of the beam, the location of the maximum moment is immediately obvious.
The beam is restrained at point A. Write your equations of static equilibrium using point A as the reference for the moments. Calculating moments about points B and C is a waste of time because the beam is not restrained at those points, and this is keeping you from proceeding with a solution.
I would like to ask can I just calculate the moment for each point A,B,C manually without drawing the BMD? As shown in post #10.
And what do you mean by "Write your equations of static equilibrium using point A as the reference for the moments."
Thank you.
In order to determine the reaction force and moment applied at A which keeps the free body of the beam in static equilibrium, you write equations which contain the unknown reactions. The beam remains in equilibrium as long as the following equations are satisfied:
∑F = 0
∑M about A = 0
For this particular beam, let's say there is an unknown reaction R[itex]_{A}[/itex] and unknown moment M[itex]_{A}[/itex] at point A. The equations of equilibrium for the beam will be:
[+ forces are pointing up; + moments are counterclockwise]
∑F = R[itex]_{A}[/itex] - 1.2 - 0.7 = 0 [kN]
∑M about A = M[itex]_{A}[/itex] -1.2 * 3 - 0.7 * 7 = 0 [kN-m]
Now, it should be easy to solve these two equations for R[itex]_{A}[/itex] and M[itex]_{A}[/itex].
Once you have done that, you can then construct the shear force and bending moment diagram for the beam.
Yes..I already calculated Ra=1900N and based on the SFD and BMD, I have found that
Ma=-8500Nm
Mb=-2800Nm
Mc=0Nm
I would like to ask without drawing the BMD, can I calculate each Moment individually?
Your shear force diagram looks OK, but the value of the bending moment at B is not -2800 Nm, and the bending moment does not go to zero between points B and C.
You use the value of the moment at A and the area under the shear force diagram to calculate the value of the bending moment at points B and C.
For example, the BM at point B = MA + Area of the shear force diagram from A to B
You should have obtained MA = 8500 Nm from the equilibrium equations, rather than -8500 Nm.
The reaction moment at A is CCW, given the direction of the the forces on the beam.
Can you calculate the bending moment values at B and C now and correct the bending moment diagram?
I am really confused on why Moment A is not - 8500Nm CW.. Can you please take a look at post #13 again? I set my orientation as +ve CW
This is the new BMD, but it don't make any sense to me. I thought for BMD you always start at 0 and end at 0. For this BMD, I start at 0 but end at 17240. Whereas for the old BMD, I start and end at 0.
This is where we differ. In Post #16, I used CCW as +moments for the equilibrium equations.
Your new bending moment diagram is incorrect because you have taken all moments as having the same sign. The moment at A must have the opposite direction of the moments at B and C, otherwise the beam cannot be in equilibrium.
So I must follow your orientation as CCW +ve, CW as -ve for all the questions if not I'm wrong? I thought we can set out own orientation but must follow accordingly...
And I thought you told me that my Ma should be +ve 8500Nm..
Thank you.
Thank you.
No, you don't have to follow my sign convention, but you must follow a consistent convention if you hope to solve the problem. The equilibrium equations I included in Post #16 are based on the sign convention as disclosed in that post. If another sign convention is chosen, then the signs of the forces and moments in those equations must be adjusted accordingly.
The reaction moment must be the opposite sign of the applied moments, otherwise, the beam cannot be in static equilibrium. That's why your last attempt at drawing the bending moment diagram was unsuccessful.
But for post #13 I did follow my sign convention consistently and why my answer is still wrong? Can you tell me which part is wrong?
Can you tell me what is the correct value for the BMD?
Thank you..
Thank you..
I showed you how to set up the equilibrium equations in Post #16, and I explained how you obtain the bending moment from the shear force diagram in Post #18. You made additional calculation mistakes in the posts after #18 (like having the moments due to the applied forces and the reaction moment at A all having the same sign), which is why you haven't progressed in your solution.
I've gone about as far as I can under the HW help rules at PF. You must show me some additional attempts at correcting your mistakes, and I will be happy to review them and provide further comment.
I still don't understand how I got my calculation wrong for moment A
Taking positive as +ve
Ma+(1200x3)+(700x7)=0
Ma+8500=0
Ma=-8500Nm CCW
Ma+8500=0
Ma=-8500Nm CCW
I told you that was right many posts ago, but i guess you were not paying attention. Continue. The moments at B and C are more easily calculated using free body diagrams of the right hand section. Sorry to be repetitive. Please watch your signage and your math! And your BMD is wrong.
I would like to extend my sincere thanks to PhantomJay :approve: for taking his time to explained where I gone wrong.
  • · Replies 22 ·
  • · Replies 25 ·
