Finding the tension of the string (vertical circular motion)
The discussion focuses on calculating the tension in a string during vertical circular motion of a ball. The ball, with a mass of 125g and a string length of 0.900 meters, is set in motion at 38 RPM. The tension at the top of the circle is calculated to be 0.553 N, while at the bottom, it is 3.01 N. There is a clarification on the conversion of RPM to period, correcting a misunderstanding about the relationship between revolutions per second and seconds per revolution. Overall, the calculations are confirmed to be correct despite the initial confusion regarding the time period.
littlebearrrr
A ball of mass 125g is attached to a string .900 meters long. It is then set into vertical circular motion with 38 RPM. What is the tension of the string at the top of the circle and at the bottom of the circle?
∑Fy = may = marad
arad = v2/R = 4∏2R/T2
First, I found T (period) by using the given RPM:
(38 rev/1 min)(1 min/60 s) = 0.633 rev/s --> 1.58 s per revolution = T
Used T to calculate arad (radial acceleration):
arad = 4∏2(.900 m) / (1.58 s)2 = 14.23 m/s2
Finding the tension at the top of the circle:
The only forces acting on the ball at the top are its weight and the tension force acting in the same direction (downward). With these facts, I apply Newton's second law for the vertical direction and solve for the tension -
∑Fy = may = marad = w + T
T = marad - w = (.125 kg)(14.23 m/s2) - (.125 kg)(9.81 m/s2) = 0.553 N
Finding the tension at the bottom of the circle:
At the bottom, the forces now oppose each other. The tension is directed upward, while the weight remains directed down. Again, I apply Newton's second law -
∑Fy = may = marad = T - w
T = marad + w = (.125 kg)(14.23 m/s2) + (.125 kg)(9.81 m/s2) = 3.01 N
Just checking to see if this is correct. Thank you in advance!
Yes, it's correct, except the part where you said 0.633 rev/s = 1.58 s per revolution. That's wrong. But it didn't affect your answer.
Likes 1 person
Ah, so it was just supposed to be 1.58s? Also, thanks for checking my answer. Appreciate it!
No, the problem is that the correct equation is 0.633 rev/s = 1/(1.58 s per revolution)
Likes 1 person
Oh, got it! Thanks for pointing that out; I fixed it above. I have a bad habit of equating the wrong things when reporting answers sometimes, even when the answer is right. I definitely need to work on that.
littlebearrrr said:
Oh, got it! Thanks for pointing that out. I have a bad habit of equating the wrong things when reporting answers sometimes, even when the answer is right. I definitely need to work on that.
That happens because you're mentally saying "equal" when you ought to say "therefore". The mathematical symbol for therefore is an arrow \Rightarrow.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
