What Is Gaetan Boucher's Total Acceleration at 1/4 Lap?
  • Thread starter Thread starter Lolagoeslala
    Acceleration
Gaetan Boucher skated around a circular track with a radius of 100m, completing a lap in 30 seconds while accelerating from rest. To find his total acceleration at the 1/4 lap mark, the tangential and radial components of acceleration must be calculated separately, as they are perpendicular vectors. The tangential acceleration was determined to be 5.58 m/s², while the centripetal acceleration was calculated based on his speed at that point. After resolving the components, the total acceleration magnitude was found to be approximately 18.38 m/s², although discrepancies in time calculations led to confusion regarding the correct answer options. Ultimately, the discussion emphasized the importance of correctly applying angular acceleration formulas and kinematic equations.
Lolagoeslala
Gaetan Boucher started from rest and skated around a circular ice track of radius 100m. He maintained a constant rate of increase of his speed and finished one complete lap in 30s. Calculate the magnitude of his total acceleration as he passed a point 1/4 of the distance around the track from the start.
v1 = 0m/s
r = 100m
d = 1/4d
a = ?
t = 30s
c = 1/4 x 2rπ
c = 157 m
t = 1/4 (30s)
t = 7.5s
157 m = (0m/s + v2)/2 (7.5s)
41.866 m/s = v2
157 m = 1/2a(t)2
5.58 m/s^2 = a
There are two accelerations to be solved for here: tangential and radial.
First get tangential accel: this should be easy from the fact that this accel is constant.
Then you need to solve for speed v at the 1/4 point. You can do that by solving for the time it takes him to go to the 1/4 point (again using the tangential accel.) , then use your value of tangential accel one more time to get v. Finally, you compute the other component of accel (hint: it's called centripetal) to get the total accel.
The total accel is not the numerical sum of the two. The two accels are separate vectors, one pointing tangential to his course and the other towards the center of the ring. If you don't know vectors just leave the answer as two separate accelerations.
Okay i am a bit confused.
you said tangential acceleration,
a = (rw) / t
right?
i have not learned the tangential acceleration thoroughly so.
a = (rw) / t
right?
What is the angular acceleration ?
using this formula ω = θ / t
but i do not know the angle .. not wait i do.
1/4 x 360 = 90 deg
ω = θ / t
ω = n/2 / 7.5s
1/4 x 360 = 90 deg
ω = θ / t
ω = n/2 / 7.5s
That's the average angular velocity for the first 1/4 of a lap.
The skater starts with ωi = 0, & averages π/(2(7.5)) rad/s ?
What is ωf at 1/4 lap ?
(Just as in the case of constant linear velocity, for constant angular velocity, ωAverage = (ωi + ωf)/2 .)
π/(2(7.5)) rad/s = (0 +ωf / 2)
π/7.5 rad/s = ωf
π/7.5 rad/s = ωf
Yes.
From ωf & ωi , you should be able to find the angular acceleration, α .
SammyS said:
Yes.
π/7.5 rad/s = at
π = a
Lolagoeslala said:
π/7.5 rad/s = at
π = a
No. Bad algebra.
t = 7.5 s ,
so a = (π/7.5)/7.5 rad/s2
SammyS said:
No. Bad algebra.
t = 7.5 s ,
a= π/56.25 rad/s^2
Lolagoeslala said:
a= π/56.25 rad/s^2
The tangential component of acceleration is \ \ a_t=\alpha R\ .
The radial component of acceleration is simply the centripetal acceleration.
like this?
π/56.25 rad/s^2 x 100 m = a
5.58 radm/s^2 = a
Lolagoeslala said:
like this?
5.58 radm/s^2 = a
That's only the tangential component.
a = 5.58 radm/m^s2
d = 200 m
C = 200 m x 3.14
C = 628 m
D = 1/4 628 m = 157 m
157 m = 1/2 (5.58 radm/m^s2)(t)^2
t = 7.5 s
157 m x 2 / 7.5 s =v2
41.866 m/s = v2
a = 41.866 m/s /100m
a = 0.041866 m/s^2
Lolagoeslala said:
a = 5.58 radm/m^s2
d = 200 m
C = 200 m x 3.14
C = 628 m
t = 7.5 s
41.866 m/s = v2
a = 0.041866 m/s^2
You went through some needless steps there.
You already have ω at t = 7.5s, which you already know is the time at the 1/4 lap mark.
v = ωR .
Centripetal acceleration is ac = v2/R .
(It's also equal to 2R)
I get a value different from yours.
By the way, rad∙m/s2 is merely m/s2 .
v = ωR .
41.866 m/s = v2
a = v^2 / R
a = 41.866 m/s^2 / 100m
a = 17.52 m/s^2
41.866 m/s = v2
a = v^2 / R
a = 17.52 m/s^2
That's about right.
Tangential acceleration is in the direction of motion. Centripetal acceleration is towards the center of the circle. Therefore, they're perpendicular to each other.
Find the magnitude of the acceleration using your two results.
a = 17.52 m/s^2[W] + 5.58 m/s^2
like this?
like this?
No.
Acceleration is a vector quantity.
Tangential component is perpendicular to radial.
SammyS said:
No.
i am bit confused i have not worked with tangential component before
In earlier posts this was mentioned, particularly in post #12.
Consider an object moving along some path. The velocity vector for the object will be along a line tangent to the path. The component of acceleration in the direction of the velocity vector is given by the time rate of change of the speed of the object: \displaystyle \frac{dv}{dt}\,,\ \ \text{ where }\ v=|\vec{v}|\ .
At any rate, the tangential component is perpendicular to radial, so use the Pythagorean theorem to find the magnitude.
c^2 = (17.52 m/s^2) ^2 + (5.58 m/s^2 )^2
c = 18.38 m/s^2
c = 18.38 m/s^2
That's correct to 3 sig. fig.
so that's the answer
i do not need to worry about the orientation?
but the answer does not match up with the answers possible.
What are the possible answers ?
1.4 , 2.99 , 4.39 , 4.60 , and 5.78
Oh ! I see what went wrong.
It takes longer than 7.5 s for the first 1/4 of a lap.
Base the angular acceleration on one complete lap.
ωf = 2ωavg = 2(2π)/30 .
Angular acceleration, α = (ωf-0)/30 . That's 1/4 of the former answer.
i am abit confused
  • · Replies 38 ·
  • · Replies 30 ·
