Finding the total energy of a Pi meson
The problem involves a K meson with a rest mass of approximately 500 MeV that decays into two Pi mesons, each with a rest mass of 140 MeV. One Pi meson remains at rest while the other is in motion, and the goal is to determine the total energy of the moving Pi meson.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using conservation of energy and momentum to analyze the problem. There are attempts to express the energy and momentum equations, and questions arise about the use of the Lorentz factor (γ) and how to handle the equations without it. Some participants suggest using the relationship between energy, momentum, and mass.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the conservation laws and the use of specific equations, but there is no explicit consensus on the next steps or final approach.
Participants note the complexity of using the Lorentz factor in this context and consider simplifying the problem by focusing on conservation principles. There is also mention of the need to leave numerical values out until later in the discussion.
AsadaShino92
A K meson (an elementary particle with approximately 500 Mev rest mass) traveling through the laboratory breaks up into two Pi mesons (elementary particles with 140 Mev rest energies). One of the Pi mesons is left at rest. What is the total energy of the remaining Pi meson?
E=mc^2
KE=(γ-1)mc^2
My first step was trying to use energy conservation E(initial)=E(final)
The K meson is traveling so the total E at the start is E(rest mass of K)+KE(K meson)
E(initial)=500 Mev+(γ-1)mc^2
In the end, the K meson breaks into 2 Pi mesons, each with 140 Mev rest mass. One stops and the other keeps on moving.
So the total E at the end is E(rest mass Pi)+E(rest mass 2nd Pi)+(γ-1)mc^2
E(final)=140 Mev+140Mev+(γ-1)mc^2
E(initial)=E(final)
500 Mev+(γ-1)mc^2=140 Mev+140Mev+(γ-1)mc^2
But now I don't know what to do next. I don't have a value for gamma.
E=mc^2
KE=(γ-1)mc^2
E(initial)=E(final)
What about momentum?
Then I would use p=γmv but I don't think I have the value for those. I just know that momentum would also be conserved.
In general it's messy to use ##\gamma## in this sort of problem. Can you think of a way to tackle the problem without it?
P=E/C ?
AsadaShino92 said:
P=E/C ?
That's for a massless particle. Do you know:
##E^2 = p^2c^2 + m^2c^4##?
So am I using this equation to solve for momentum?
The general approach to these particle problems is:
1) Conservation of energy
2) Conservation of momentum.
3) For each particle: ##E^2 = p^2c^2 + m^2c^4##
Hint: stick with ##M## for the initial K meson mass and ##m## for the pi meson mass and leave the numbers out until the end.
The notation is up to you, but I would use ##E_0, p_0## for the Energy & Momentum of the initial K meson; ##E_1, p_1 (p_1= 0)## for the pi meson that ends up at rest and ##E_2, p_2## for the second pi meson.
You're trying to solve for ##E_2## of course.
Using the notation, I have the conservation of energy written as E0=E1+E2
Then using the energy equation for each particle
For the K meson
E02=P02C2+M2C4
For the Pi stopped
E12=m2C4 since P1=0
For Pi moving
E22=P22C2+m2C4
Momentum conservation
P0=P1+P2
Since P1=0
P0=P2
Do I just plug all this into E2=E0-E1?
Why not? You may want to square that equation first.
You mean instead I should use E22=E02-E12?
##(E_0 - E_1)^2 \ne E_0^2 - E_1^2##
My mistake. Then squaring both sides should be E22=(E0-E1)2
##E_2^2 = (E_0 - E_1)^2 = \dots##?
(E0-E1)2=E02-2E0E1+E12
Okay, but you may need to do more than one line of algebra at a time. I'm going off-line now, but maybe someone else can provide further help if you need it.
  • · Replies 54 ·
12K
