Finding the total mechanical energy
The problem involves a bead sliding on a surface, with specific heights and speeds at points A, B, and C. The discussion centers around calculating the bead's speed at points B and C using principles of mechanical energy conservation, given that the mass of the bead is not provided.
  • Participants discuss the conservation of energy and how to express the total mechanical energy (TME) at different points. There are attempts to relate kinetic energy (KE) and gravitational potential energy (GPE) without the mass of the bead, leading to questions about how mass affects the equations.
Participants are exploring different formulations of the conservation of energy equation and questioning the role of mass in the calculations. Some guidance has been offered regarding the cancellation of mass in the equations, and there is an ongoing dialogue about the correct expression for total mechanical energy.
The problem is constrained by the absence of mass, which is leading to confusion in the application of energy equations. Participants are encouraged to consider hypothetical values for mass to aid in their understanding.
Sophie Martinez
A bead is sliding on a surface. At point A it is 80 cm above the ground, at point B it has just hit the ground and at point C it is 50 cm above the ground. At point A it has a speed of 200 m/s, so what will its speed be at point B and C?
W=F.d
Kinetic Energy= (mv^2)/2
Gravitational potential energy= mass • 9.8 • height
I tried to find the the total mechanical energy at one point by adding the GPE and KE. At point B the GPE is 0, so the kinetic energy will be the total mechanical energy due to the conservation of energy. The mass is not given in this question and without the mass I cannot figure it out. I tried equating the work and energy equatipns but o got the wrong answer.
If you write the equation for conservation of energy, you'd see that the mass term is canceled out.
At point A, the bead has both KE and PE and at point B, it has only KE. How would you write an equation describing this using the principle of conservation of energy?
Hello Sophie, :welcome:
I tried equating the work and energy equations
Way to go. Why don't you post your working and we'll try to see what goes wrong.
Tip: in don't know situations just pick something (2 kg for example) and see if it divides out.
I think the equation would only be TME=(mv^2)/2 but because the mass is canceled it would be (v^2)/2?
Yes, but energy is not v2/2.
You need to write the complete equation.
Cancelling out the mass will only leave one unknown v in the equation.
I ended up with F•d=mgh and F•d=(mv^2)/2 because of the work-energy principle. I also tried to isolate m in each case and equated the two results and got (F•d)/gh=2(F•d)/v^2
So the complete one would be TME= v^2/2 + gh?
Nope. Again, that's not an equation for energy because there's no mass term in it.
You need to use the "conservation" of energy equation.
If you say instead "TME per unit mass" that will work.
  • · Replies 21 ·
  • · Replies 22 ·
