Finding the total mechanical energy
8 replies · 3K views
Sophie Martinez
A bead is sliding on a surface. At point A it is 80 cm above the ground, at point B it has just hit the ground and at point C it is 50 cm above the ground. At point A it has a speed of 200 m/s, so what will its speed be at point B and C?
W=F.d
Kinetic Energy= (mv^2)/2
Gravitational potential energy= mass • 9.8 • height
I tried to find the the total mechanical energy at one point by adding the GPE and KE. At point B the GPE is 0, so the kinetic energy will be the total mechanical energy due to the conservation of energy. The mass is not given in this question and without the mass I cannot figure it out. I tried equating the work and energy equatipns but o got the wrong answer.
If you write the equation for conservation of energy, you'd see that the mass term is canceled out.
At point A, the bead has both KE and PE and at point B, it has only KE. How would you write an equation describing this using the principle of conservation of energy?
Hello Sophie, :welcome:
I tried equating the work and energy equations
Way to go. Why don't you post your working and we'll try to see what goes wrong.
Tip: in don't know situations just pick something (2 kg for example) and see if it divides out.
I think the equation would only be TME=(mv^2)/2 but because the mass is canceled it would be (v^2)/2?
Yes, but energy is not v2/2.
You need to write the complete equation.
Cancelling out the mass will only leave one unknown v in the equation.
I ended up with F•d=mgh and F•d=(mv^2)/2 because of the work-energy principle. I also tried to isolate m in each case and equated the two results and got (F•d)/gh=2(F•d)/v^2
So the complete one would be TME= v^2/2 + gh?
Nope. Again, that's not an equation for energy because there's no mass term in it.
You need to use the "conservation" of energy equation.
