Finding velocity and displacement from a differential equation
  • Thread starter uzman1243
    Kinetics
8 replies · 2K views · last reply
uzman1243
Diagram of a freight train on tracks: a blue diesel locomotive pulls two red boxcars to the left, with an arrow above the locomotive pointing right for velocity v and a bracketed distance s marked at the left end of the train.
v = ds/dt
∫v dt = ∫ds
(put all inital values for V)
∫70-70e^t dt = ds
70t - 70t*e^t = s
There is something wrong with my methodology. can you guide me here?
  • Diagram of a freight train with a blue diesel locomotive on the right and two red boxcars, with a distance marked s from a point on the left to the rear of the train, and an arrow above the locomotive labeled v pointing right. Text above gives v = v0(1 − e^(−bt)) and asks for the distance travelled in time t1, with v0 = 70 m/s, b = −1 and t1 = 3 s.
Looks like you did not integrate [itex]e^{-bt}[/itex] correctly. Check you last eqution. You have something extra there.
uzman1243 said:
∫70-70e^t dt = ds
70t - 70t*e^t = s
Are you sure that is the correct integral?
Edit:
Sorry, I didn't see Mr-R's post when I posted this
∫v0 (1-e^(-b*t))
∫v0 - v0*e^(-b*t)
= v0*t - V0*e^(-b*t) + c
is that correct?
uzman1243 said:
∫v0 (1-e^(-b*t))
∫v0 - v0*e^(-b*t)
is that correct?
Well the constant c is nice :smile:. Missing something from [itex]e^{-bt}[/itex] when you intagrated it though.
Edit: are you writing b explicitly or just its value? If you just substitute its value there then your integral is correct. (looks like you did not)
Can you show me the integration?
Of course I can, but I know you can do it by yourself so I will give an example.
[itex]∫e^{Cx}dx=\frac{1}{C}e^{Cx}+c[/itex]
Can you see you mistake and fix your integral now?
v0*t + (V0*e^(-b*t))/b + c
Yes. That should be it? Now I sub in all the values and find the constant C and my final answer for distance is -1126m. The answer is correct but it should be a positive value.
Is this because my answer is displacement and the question requires distance (just magnitude only)?
Well the function describes a train moving with a velocity that has a negative sign(if b=-1 see below). If they defined the positive direction to be the right direction. Then the function gives you a backwards moving train.
See the attached file,
The first graph is your given equation (velocity). The second graph is the distance which you found by integrating.
Examine the given equation(velocity) and you will notice that "b" is the constant which makes the velocity to be positive or negative. If b=1 then the train will travel in the positive direction and you will end up with positive distance.
  • Two Mathematica plots of curves against t from 0 to 3, both falling below zero: top, Plot[70 - 70*E^(t)], starting near 0 and dropping to about -1300; bottom, Plot[70 t - 70*E^(t)], starting near -70 and dropping to about -1200.
