Finding Work Done with Integration
4 replies · 5K views
armolinasf
There's a cone with height 12 feet and radius 4 feet. It is filled with water to a depth of 9 feet. Find the work required to pump the water over the top. The density of water is 62.4lbs/ft^3
work=force*distance & force=volume*density
F=pi(r^2)*62.4 and r=(12-y)/3 by similar triangles
the distance should be 12-y
Putting this together, my integral looks like this:
62.4[tex]\pi[/tex]/9 [tex]\int^{9}_{0}[/tex](12-y)[tex]^{3}[/tex]dy
evaluating gives 37491 ft-lbs, but the answer in my book is 27788 ft-lbs
If someone can point out where I'm going wrong, it would be much appreciated.
Sorry I should have mentioned this, it specifies that the cone is actually pointing downwards
As Dick said: "If y is the distance from the bottom of the cone and r=(12-y)/3 then r=0 at the top of the cone and r=4 at the bottom."
That is pointing UP !
As you said, the cone is pointing downwards.
Wow I should have caught that...thanks for the help
