Can the First p Digits of Pi Repeat Twice?
  • Thread starter Thread starter LeBrad
    Finite Pi
The discussion centers on whether the first p digits of pi can repeat as the first p/2 digits twice. It is noted that while some irrational numbers can have repeating patterns in their decimal expansions, pi has been calculated to a trillion digits without any such repetition. The concept of "finite periodicity" is introduced, suggesting that while it may appear that digits repeat over a limited range, true periodicity cannot occur in pi since it is not a rational number. The probability of finding such a repetition in pi, assuming its normality, is considered to be less than 1/9. Overall, the consensus is that while theoretically possible, the occurrence of such repetition in pi is highly unlikely.
LeBrad
If I take the first p digits of pi, is it possible that what I will have is the first p/2 digits repeated twice?
For example, suppose pi = 3.14153141529485729487... and I took the first 10 digits and got 3141531415 which is 31415 repeated twice. Can this happen?
Mathematics news on Phys.org
It's conceivable that there exists irrational numbers where the first n digits in the decimal expansion repeat themselves and then after 2n digits, it goes non-repeating, but that's not true with pi, at least to a trillion digits.
/edit
Infact, it's not just conceivable, it's pretty obvious!
\sqrt{2} = 1.4 \ldots Therefore 0.123123 + \frac{\sqrt{2}}{10^{7}} is irrational, but has the first three digits repeat.
/edit
Yeah, I knew it wasn't true for arbitrary irrationals because the first example I thought of was (101010+pi) which is irrational and repeats 10 to start. I guess I was looking for existence of evidence that it happens in pi or if there's some way to prove that this never happens for some number.
Pi can been calculated to i think its 14 trillion digits? No pattern found, but there are yet no proofs as to why, or even that each digit occurs infinity in the decimal expansion...
It is quite possible that for some n, the second n digits in \pi are just the first n repeated but, if so, it must be some exceptionally large n. No one knows for sure but I would consider it unlikely.
I notice you titled this "periodicity of \pi" which implies a block of digits repeating over and over again, forever. Since \pi is NOT rational, that certainly cannot happen.
By "finite periodicity" I meant that the first n numbers are repeated a finite number of times, so it may appear periodic if you only look at the first k*n digits.
Ah. In that case, as everyone else has told you- possible, unknown, very unlikely! (Unlikely that the first n numbers repeat k times for some n, k. Highly likely that some set of n numbers repeats k times in a row but still unknown.)
With the assumption of normality of pi, can we calculate the probability that this statement is true for some p?
I think for a normal number the probability is less than 1/9.
