How Do You Solve the Differential Equation kxy = (y+dx)(x+dy)?
r16
I have run into this problem solving differential equations of this type (they occur often doing momentum problems):
kxy = (y+dx)(x+dy)
where k is constant. I multiply it out to :
kxy= xy + xdx + ydy + dydx
Regroup and :
\int {kxy} = \int {xdx} + \int {ydy} + \int {dydx} [/itex] <br /> <br /> I&#039;m left with the term \int dxdy that I don&#039;t know what to do with. Am I able to hold either the dx or dy constant and integrate with respect to the other? I am not able to find a transformation that will remove the dydx or \frac{dy}{dx} or \frac{dx}{dy}. I am also confused about the term \int kxy: integration without respect to a particular differential. How would I solve this differential equation?
There something wrong with your equation. You can't have "dx" and "dy" mixed like that. If you are dealing with "differentials" dx and dy, it might make sense (but it would just say kxy= xy) but it is certainly not a differential equation.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
