First order differential equations
The discussion revolves around a first order differential equation of the form \(\frac{dx(t)}{dt} + ax(t) = f(t)\) with a specific input signal \(f(t) = e^{-t}\). Participants are tasked with finding the solution and determining conditions on the parameter \(a\) for the solution to approach zero as \(t\) approaches infinity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the solution to the homogeneous equation and discuss the need for a particular solution to the inhomogeneous equation. There are questions about the integration constant and the use of integrating factors. Some suggest trying a function of the form \(C(t)e^{-at}\) to simplify the equation.
The discussion is active with various approaches being considered, including the use of integrating factors and trial solutions. Some participants express confusion about the rationale behind certain steps, while others provide insights into the characteristics of the differential equation that guide the choice of methods.
Participants are navigating the complexities of first order linear differential equations, with some expressing uncertainty about the necessity of integrating factors and the appropriateness of certain trial solutions. The discussion reflects a range of interpretations and attempts to clarify the problem setup and solution strategies.
DmytriE
Consider the first order differential equation
[itex]\frac{dx(t)}{dt} + ax(t) = f(t), x(0) = x_{0}, t\geq0[/itex]​
Suppose the "input signal" [itex]f(t)=e^{-t}, t\geq0[/itex]. (a) Find the solution to the equation. Find a condition on the parameter a so that the solution of the (forced) system approaches zero as t→∞.
[itex]\frac{dy}{dt} + p(x)y = 0[/itex]
Setup as a homogenous equation therefore f(t) = 0.
[itex]\frac{dx(t)}{dt} + ax(t) = 0[/itex]
[itex]\frac{dx(t)}{x(t)} = -a*dt[/itex]
[itex]ln(x(t)) = -at[/itex]
[itex]x(t) = e^{-at}[/itex]
I don't know how to proceed any further...
What you found satisfies the homogeneous equation. You are still missing an integration constant.
Now you need one particular solution that satisfies the inhomeogeneous equation.
A times homogeneous solution + particular solution is ' the ' general solution
Is the integration constant [itex]e^{\int x(t) dt}[/itex] or [itex]e^{\int a dt}[/itex]?
I guess the only integration factor that makes sense is the later of the two.
No, I mean [itex]x(t) = Ce^{-at}[/itex] also satisfies the homogeneous equation.
Next thing to try: [itex]C = C(t)[/itex]. Put this in the inhomogeneous equation and see what equation you get for C.
I'm sorry but you've now lost me. Why am I trying C=C(t)?
Well, the [itex]e^{-at}[/itex] part of [itex]x(t) = C(t)e^{-at}[/itex] helps you get rid of the [itex]+a x(t)[/itex] term. In return, you are left with a differential equation for [itex]C(t)[/itex] that you may be able to solve.
Either use Method of undetermined coefficients or use the integrating factor [itex]e^{at}[/itex].
How can you tell when a first differential needs to use an integrating factor?
The differential equation you have presented is a linear differential equation of first order and this immediately tells us to use the integrating factor.
In this case, you don't need an integrating factor. Just put ##x(t)=Ce^{-t}## into the equation and solve for C. You can't always do that but it's a nice shortcut here. Can you see why you could guess it would work? In general, guessing a trial solution is often a good option. When you can.
Look at the left side of your equation. "a" is a constant, so it is certainly going to integrate nicely. If "a" can be integrated easily with respect to t, that's your first indicator. Now look at the right side of the equation. It's a function only of t. So, when you multiply both sides by the integrating factor, the right side will still only be a function only of t (that can be integrated). That's your second indicator.
Chet
Perhaps it's good to give a general derivation of the integrating factor for 1st-order linear ODEs. The standard form of such an ODE is
[tex]y'(x)+p(x) y(x)=q(x),[/tex]
where [itex]p[/itex] and [itex]q[/itex] are given functions and the equation is to besolved for [itex]y(x)[/itex]. We look for the general solution.
The equation would be much easier, if we had a total derivative on the left-hand side, but that's not too difficult to achieve. You just substitute
[tex]z(x)=v(x) y(x).[/tex]
From the product rule you get
[tex]z'(x)=v(x) y'(x)+v'(x) y(x).[/tex]
Multiplying the ODE with [itex]v(x)[/itex] gives
[tex]v(x) y'(x)+p(x) v(x) y(x)=q(x) v(x).[/tex]
To make the left-hand side equal to [itex]z'(x)[/itex] you obviously have to determine [itex]v(x)[/itex] so that
[tex]v'(x)=p(x) v(x)[/tex]
This is very easily solved, because you can write
[tex]\frac{\mathrm{d}}{\mathrm{d} x} \ln \left (\frac{v(x)}{v_0} \right )=p(x).[/tex]
This gives
[tex]v(x)=v_0 \exp \left (\int_{0}^{x} \mathrm{d} x' p(x') \right ).[/tex]
Here [itex]v_0 \neq 0[/itex] is an arbitrary integration constant.
Thus, choosing [itex]v(x)[/itex] in this way we can write our ODE as
[tex]z'(x)=q(x) v(x)[/tex]
with the general solution
[tex]z(x)=z_0 + \int_0^{x} \mathrm{d} x' q(x') v(x').[/tex]
Finally we have
[tex]y(x)=\frac{z(x)}{v(x)}=\frac{z_0}{v(x)}+\frac{1}{v(x)} \int_0^{x} \mathrm{d} x' q(x') v(x').[/tex]
As you see, the choice of [itex]v_0[/itex] doesn't affect your solution in any way, because it only appears as an overall factor in front of the integration constant [itex]z_0[/itex], and this can be lumped into the overall integration constant of the general solution of the homogeneous equation. Finally we have the general solution of the ODE
[tex]y(x)=\exp \left (-\int_0^{x} \mathrm{d} x' p(x') \right ) \left [y_0+ \int_0^x \mathrm{d} x' q(x') \exp \left ( \int_0^x \mathrm{d} x'' p(x'') \right ) \right].[/tex]
Here [itex]y_0[/itex] is given by the initial-value condition [itex]y(0)=y_0[/itex].
Thank you everyone! I finally figured it out using integrating factors. As for guessing, would you guess Ce^-t as a good solution because the function is forced by e^-t?
It's a good guess because of the other side of the equation, if you differentiate ##e^{-t}## or multiply it by ##a##, you just get back multiples of ##e^{-t}##.
  • · Replies 105 ·
11K
  • · Replies 23 ·
