Fixing Missing Headlight Bulb on 200w Electric Scooter
  • Thread starter Thread starter pow210
    Electric Scooter
A user reported receiving a 200w electric scooter missing its headlight bulb, which requires a difficult-to-find 24v bulb. Suggestions included contacting the manufacturer in China for assistance or checking for a 12v output on the battery, considering the implications for other lights. The user found a solution by modifying a 24v bulb from an HGV trailer, achieving satisfactory performance. The scooter can reach a maximum speed of 15mph, classifying it as a bicycle, with potential modifications to increase speed at the cost of range. The discussion highlights the challenges of sourcing parts for imported scooters and the importance of understanding local regulations.
pow210
Hi, I recently purchased a electric scooter (Chinese), 200w motor and with 48v batteries, unfortutunately it arrrived missing the headlight bulb! it transpires that it is a 24v bulb, rather diificult to get here so it there a easy soloution to lower the wiring down to 12v (other than to buy British next time!).
Thanks.
There are lots of ways to drop 24 volts to 12, but before you think about those, have you tried contacting the Factory in China about this? They might have a web site.
If you can't get any cooperation, contact the Chinese embassy for the phone number of their trade people. I imagine they'd love to hear from you.
In the life of the scooter, you may need more lamp bulbs, so it would be worth getting 3 or 4 now if you have the chance.
If you really, really can't get another lamp, you could look at the battery and see if there is an accessible 12 volt output on it.
However this will mean you also have to know what else runs off the headlight switch. Probably the tail lights also get this same voltage, so they would have to be 12 volt ones as well. Also, the indicator lights and the indicator flash unit.
You could put two headlight lamps in series, I guess, but they can't both be at the focal point of the headlight reflector.
Did you buy it from a local agent or did you get it sent from China?
If there was an agent, it is their problem.
If it was brought in directly, do you know the procedure for getting it licensed?
It could cost thousands if the licensing people have never seen one before.
Sounds like a fun scooter, though.
Is 200 watts enough? How fast can it go?
Hi problem solved, got HGV trailer 24v bulb and modified fitting. Only 5w but off a 48v battery sure is good.Max speed allowed on GB roads is 15mph so still classed as a bicycle (but looks so like a scooter), restrictor can be by-passed to double speed but obviosly halves travel ie. approx. 10miles instead of 20 per charge. Thanks
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
