What is a quick way to approximate flight time off a cliff?
  • Thread starter Thread starter grayb
    Flight Time
To approximate the flight time of a projectile thrown off a cliff, three scenarios are considered: when the initial vertical velocity (v_y) is positive, zero, or negative. For v_y > 0, the flight time can be calculated by determining the time to reach the peak height and then the time to fall from that height. If v_y = 0, the flight time is derived from the free fall equation, t = sqrt(H/5). When v_y < 0, a quick approximation can be made, although the exact method requires further clarification. The discussion emphasizes the use of the SUVAT equations to model the motion under constant acceleration.
grayb
Hi, I'm basically trying to figure out if there's a quick way to approximate the flight time of something thrown downwards off a cliff.
If you throw a projectile off a cliff with height H > 0 above the ground, there are 3 cases:
v_y > 0
v_y = 0 (thrown horizontally off the cliff)
v_y < 0
For v_y > 0, it takes about v_y/10 seconds = t1 to reach the peak above the cliff and the new height is about H + (v_y)^2/20. Since v_y = 0 at the peak, it's like a freefall question from height H + (v_y)^2/20, so you can set H + (v_y)^2/20 = 5t^2, t2 = sqrt(H+(v_y)^2/20) and the total flight time is about t1 + t2.
If v_y = 0 then it's free fall and H = 5t^2 so t = sqrt(H/5).
For v_y < 0 (thrown downwards off a cliff), how can I approximate it without doing a quadratic equation? I guessed t1 + t2 - 1 but I'm not sure if that's right.
Thanks!
Science news on Phys.org
If you assume constant acceleration the SUVAT equation..
s = ut + 0.5at2
(where u is the vertical velocity)
applies apply to all three cases.
One approximation you could make is to assume u is small.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
