Flow of current. Conductors and Insulators.
When two neutral conductors touch, no current flows between them. A neutral conductor will allow current to flow when it touches a positively charged conductor, moving from neutral to positive. Conversely, current flows from a negatively charged conductor to a positively charged one upon contact. However, when a neutral conductor touches a positive insulator, no current flows. Clarification on these principles can help resolve confusion regarding conductor and insulator interactions.
girlzrule786
This is NOT a homework question.. It is just something that is bothering me...
1. If two neutral conductors are made to touch each other, no current will flow..
2. If a neutral conductor is made to touch with a positive conductor, the current will flow from the neutral to the positive conductor...
3. If a negatively charged conductor is made to touch with a positively charged conductor, the current will flow from the negative to the positive conductor..
4. If a neutral conductor is made to touch a positive insulator, the current will not flow...
Which of these is true?? This is really confusing me... Please help, I need it...
It may not be a homework problem, but it looks an awful lot like a take-home test. What part exactly are you confused on?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
