Flow of energy in a cylindrical conductor
The flow of energy in a cylindrical conductor with radius 'a', resistivity 'ρ', and carrying a constant current 'I' is calculated using the formula ρ I² l / π a². The discussion emphasizes that the energy dissipated due to resistance can be conceptualized as entering through the cylindrical sides of the conductor, linking the thermal energy increase to the field energy. The Poynting vector, which represents the rate of energy flow, is crucial in understanding this relationship, although some participants noted discrepancies in dimensional analysis and the interpretation of the problem.
  • Cylindrical conductor properties
  • Understanding of resistivity (ρ) and current (I)
  • Concept of the Poynting vector in electromagnetism
  • Basic principles of energy dissipation in resistive materials
  • Study the derivation and applications of the Poynting vector in electromagnetic theory
  • Explore the relationship between electric fields and resistivity in conductors
  • Investigate thermal energy generation in resistive materials under current flow
  • Learn about dimensional analysis in physics equations to ensure correctness
Students of electrical engineering, physicists studying electromagnetism, and anyone interested in the principles of energy flow in conductive materials.
kent davidge
A cylindrical conductor with a circular cross section has a radius a and a resistivity ρ and carries a constant current I. What is the flow of energy into the volume occupied by a length l of the conductor? Discuss why the energy dissipated in a current carrying conductor, due to its resistance, can be thought of as entering through the cylindrical sides of the conductor.
no
[/B]
(first of all, sorry my bad english)
I found it to be ρ I² l / π a²
Now my answer for why can we think the flow as entering on the conductor is that the field energy is the cause of the increase of the thermal energy, and thus it must be equal each other. Is it ok?
Do you mean ##\rho I^2l/(\pi a^2)##? If so, that does not have the right dimension for power.
Even if you don't mean that, it does not look right to me.
The second part of the question strikes me as strange. Is it a translation? The only thing that comes to mind is how the power is distributed along the length.
kent davidge said:
no
Really?
DrClaude :smile:
haruspex, is this the second part you've mentioned? "Discuss why the energy dissipated in a current..." If so, it's how the problem was written by the author.
I'll show you how I found my answer for the flow.
The magnitude of the electric and magnetic fields are ρ I / (π a²) and μ I / (2 π a), respectivelly. The magnitude of the Poynting vector is the ratio of power (rate of flow energy) and area. Then, considering the length as L = 2 π a, I multiplied it by both the area and the intensity of energy (magnitude of the Poynting vector) to find the power.
kent davidge said:
The magnitude of the electric and magnetic fields is ρ I / (π a²) and μ I / (2 π a), respectivelly.
What is ##\rho## in that expression? I don't see how resistivity will affect the electric field. I don't see the relevance of the magnetic field either.
kent davidge said:
. The magnitude of the Poynting vector is the ratio of power (rate of flow energy) and area. Then, considering the length as L = 2 π a, I multiplied it by both the area and the intensity of the energy (magnitude of the Poynting vector) to find the power.
You are asked for the flow of energy, not the flow per unit area.
L = 2 π a makes no sense. a is an area, and the length given is not a circumference.
Seems to me you are making the question far more complicated than it is. What is the resistance of the conductor?
No, a is the radius of the cylindrical conductor. But It's okay. Now I would like to know if my explanation about why the thermal and field energies were equal is correct.
Kent, I think it would have helped if in your first post you had made it clear that you were dealing with the Poynting vector. (Therefore, DrClaude's comment:smile:)
You did not show any of your work in the first post, so it was not evident how you got your expression for the rate at which field energy is flowing into the section of the conductor.
Does your answer agree with what you would calculate to be the rate at which energy is being dissipated inside the material due to the current flowing through a resistance?
Sorry, my mistake. But the rest of my comments stand.
  • · Replies 23 ·
  • · Replies 18 ·
