How does the change in area affect the velocity of helium gas in a vacuum?
The discussion centers on calculating the exit stream velocity of helium gas in a vacuum system, specifically under conditions of gauge pressure at 0.065 psi. Participants emphasize that Bernoulli's equation cannot be applied directly due to the compressible nature of the flow and the presence of pressure losses between the inlet and outlet. Instead, they recommend using the compressible form of Bernoulli's equation and calculating the density of helium using the ideal gas law (ρ = P*MW/(RT)) to determine the outlet velocity accurately.
  • Understanding of Bernoulli's equation and its limitations in compressible flow scenarios.
  • Familiarity with the ideal gas law for calculating gas density.
  • Knowledge of mass flow rate and its implications in fluid dynamics.
  • Basic principles of vacuum systems and their effects on gas behavior.
  • Study the compressible form of Bernoulli's equation for gas dynamics.
  • Learn about the ideal gas law and its application in calculating gas density under varying pressures.
  • Research the effects of pressure losses in fluid systems and how to account for them in calculations.
  • Explore advanced fluid dynamics concepts related to compressible flow and mass flow rate calculations.
Engineers, physicists, and students involved in fluid dynamics, particularly those working with gas flow in vacuum systems and needing to understand compressible flow behavior.
ilc
Hello
here is a schematic of the problem: http://imgur.com/CgcybVT
A stream of helium gas will be used to carry aerosolized particles.
I am assuming conservation of mass (and mass flow)
The mission is to find the exit stream velocity of the gas
. For the time being, i am assuming the weight of particle is negligible and doesn't reduce helium velocity.
I am using Bernoulli's equation... would it be correct to only focus on the inlet and exit ?
I feel the changes in area matter because as area increases, velocity decreases to maintain constant mass flow.
Advice?
Thanks!
EDIT: I forgot to mention the system is under vacuum, and he outlet pressure of 0.065 psi is that of the vacuum chamber
here is a better diagram: http://imgur.com/64b7WLT
1) You can't use only the inlet and outlet since there are a lot of things in between there that are "lossy" in terms of pressure. In other words, not all of that pressure is going to be converted to velocity.
2) It appears that what you are reporting here is gauge pressure. If so, that strongly implies to me that this flow is likely compressible and you can't use Bernoulli's equation at all.
There's a compressible form of Bernoulli equation, right?
More of a "compressible generalization", but yes. Unfortunately, it is not very simple to use.
Hi:
Hi there,
it appears I forgot to mention the system is under vacuum... and the outlet pressure of 0.065 psi is that of the vacuum chamber
We can assume vacuum extends upto the inlet Helium stream. This means density of Helium will change once it leaves the gas tank and that its compressible. As such, it makes calculate the density (rho = P*MW/(RT)) at vacuum pressure, right ?
With regards to your comment in 1): since i am assuming constant mass flow, couldn't i use rho*V*A between sections and work my way up to calculate the outlet velocity?
  • · Replies 20 ·
  • · Replies 45 ·
  • · Replies 51 ·
9K
