Calculating Max Flow Rate Through Pipe System
Calculating the maximum flow rate through a 4" SDR 11 HDPE pipe system involves considering the pipe's internal diameter, elevation change, and roughness value. The user seeks to determine the appropriate centrifugal pump size to achieve the desired flow rate, noting the challenge of lacking initial velocity or flow rate data. A system diagram can help model flow loss and select a pump characteristic curve for optimal performance. Adding a second pump in series can increase flow rate by combining head ratings, but careful placement is crucial to avoid exceeding the pipe's pressure rating. Ultimately, the decision on pump placement—whether at the source or downstream—will impact the system's pressure and flow dynamics.
Jbucky21389
Is it possible to calculate the max flow rate (gals/m) achievable through a given piping system with only the following variables?
- 4" SDR 11 HDPE pipe (3.633" ID)
- 28,000 feet of pipe from source to destination
- 90' of elevation change from source to destination
- destination is another pond, pipe is open ended and 90' higher than source.
- 150 roughness value
I'm trying to figure out what size of centrifugal pump to place at the source pond and what flow rate is possible. I'm not very smart about this type of thing. I Googled it, but every calculator I found wanted either velocity or flow rate, which I don't know because there is no pump there yet..? Thank you.
When I designed piping systems as an ancillary job, my component catalogues all listed flow loss D/L per component or foot. Use that to model the system - a system diagram - pick your pump characteristic (curve) to intersect the system diagram at your desired flow rate.
Great, got that figured out. Thanks. Now, I have another question... how would adding another pump in series affect the pressure on the pipe? I understand that with two centrifugal pumps in series, having equal specifications, you would add their head ratings together which would slide the desired flow rate further out on the system curve thereby increasing the flow rate. I guess what I'm trying to get at is to get better flow rate would I put the series "booster" centrifugal pump piggy-backed onto the discharge of the first pump right at the source, or would I be better off to put it a couple miles downstream in the piping system? Putting it in series right at the source pond pump would probably increase the pressure at the outlet of the booster pump so much so that the pipe's pressure rating would be exceeded?
I'm not a student or graduate in Astrophysics.. Wish i were though... I was playing with distances between planets... I found that Mars, Ceres, Jupiter and Saturn have somthing in common... They are in a kind of ratio with another.. They all got a difference about 1,84 to 1,88x the distance from the previous planet, sub-planet. On average 1,845x. I thought this can be coincidential. So i took the big moons of Jupiter and Saturn to do the same thing jupiter; Io, Europa and Ganymede have a...
