Fluid mechanics, open water channel velocity - bernoulli & conservation of flow
The discussion focuses on calculating the velocity of an incompressible ideal fluid in an open water channel with a small bump. The derived formula for the velocity \( v_2 \) directly above the bump is \( v_2 = \sqrt{\frac{2g\Delta h}{(\frac{h_1}{h_2})^2 - 1}} \). The relationship between the fluid heights and velocities is established using Bernoulli's equation and the conservation of flow principles. The conditions specified include negligible losses and a small bump height compared to the fluid depth.
  • Understanding of Bernoulli's equation
  • Knowledge of fluid dynamics principles
  • Familiarity with the concept of incompressible fluids
  • Basic algebra for manipulating equations
  • Study the derivation of Bernoulli's equation in fluid mechanics
  • Explore the implications of conservation of mass in fluid flow
  • Investigate the effects of turbulence on flow velocity
  • Learn about practical applications of flow measurement techniques
Students studying fluid mechanics, engineers working on hydraulic systems, and anyone involved in fluid flow analysis in open channels.
mh1985
If in an open water channel, the approach speed of an incompressible ideal fluid, of constant depth h1, is not too large, a small bump in height H (H<< h1) in the base of the channel will cause a dip Δh (Δh << H) in the water level directly above it, such that h1 = Δh + H + h2, where h2 is the height of the fluid above the bump.
Under these conditions, such an arrangement can be used for measuring the flow velocity
Q. Assuming no losses, show that the velocity v2, directly above the bump is given by
[tex]v_2 = [\frac{2gΔh} {(\frac{h1}{h2})^2 - 1}]^\frac{1}{2}[/tex]
[tex]0.5*u^2 + gh_1 = 0.5* v_2^2 + g(h_2 + H)<br /> <br /> g (h_1 - (H + h_2) = 1/2 (v_2^2 - u^2) = g \delta h[/tex]
We want the expression for [tex]v_2[/tex]
[tex]v_1h_1 = v_2h_2[/tex]------->[tex]v_1 = \frac {v_2h_2}{h_1}[/tex]
Thanks for the help!
can anyone help?
9K
