Graduate Is Transient Flow Caused by Changes in Velocity's Direction in Pipelines?
  • Thread starter Thread starter Mikealvarado100
    Fluid Transient
Transient flow in pipelines is primarily associated with changes in the quantity of velocity rather than changes in its direction. While a bend in a pipe alters flow direction and exerts forces on the fluid, this does not inherently create transient flow. Steady flow can still occur in a bend if the flow field remains constant over time. The distinction lies in whether the flow characteristics change with time, not merely in the geometry of the pipe. Therefore, transient flow is not solely a result of directional changes in velocity.
Mikealvarado100
Hi every one;
Transient [Fluid Transient in Pipelines] is result of changing in momentum and momentum is result of changing in velocity. Velocity is a vector parameter. It means that Velocity's change is due to changing in velocity's quantity or velocity's direction. All discussions about transient Analysis (in books and references) speaks about Transient as result of changing in AMOUNT of velocity not changing in DIRECTION of it.
Assume a pipe with no operations or branches, valves or ... but there is a Bend along the pipe. Changing in velocity's direction makes momentum and therefore it must makes a transient. Am I right or I make mistake and Transient is due to JUST velocity's quantity?
Thanx in advance.
I am not sure why you are using the word transient to describe flow in a bend. One could have steady flow in a bend. Yes, a bend will alter the flow direction and must therefore exert a force on the fluid. This doesn't make it a transient flow, however. If the flow field does not change with time, then it is a steady flow regardless of the shape of the pipe.
Likes Chestermiller and Nidum
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 51 ·
37K
  • · Replies 31 ·
  • · Replies 35 ·
  • · Replies 30 ·
  • · Replies 21 ·
