Flux of electric field through the square
The discussion focuses on calculating the electric flux through a square surface in the xy-plane due to a point charge of q = 8.85 μC located at (0,0,h). The relevant equation for flux is derived from Gauss's law, specifically Flux = Charge/permittivity. The participant successfully determined the flux for h = 0.05 L by conceptualizing the surface as part of a cube and using the formula 4*arcsin((a^2)/(a^2+4*h^2)) to find the solid angle, ultimately leading to the correct answer without the need for integration.
  • Understanding of electric flux and Gauss's law
  • Familiarity with solid angles in three-dimensional geometry
  • Basic knowledge of integration and its applications in physics
  • Concept of permittivity in electrostatics
  • Study the derivation and applications of Gauss's law in electrostatics
  • Learn about calculating solid angles in various geometrical configurations
  • Explore the concept of electric field lines and their relation to flux
  • Investigate the role of permittivity in different media and its effects on electric fields
Students and professionals in physics, particularly those focusing on electromagnetism, electrical engineers, and anyone involved in solving problems related to electric fields and flux calculations.
leventa2
A small particle, with charge q = 8.85 μC, is located at (x,y,z) = (0,0,h). Calculate the flux of electric field through the square in the xy-plane, of size L × L, centered at the origin.
(B) What is the flux if h = 0.05 L?
Flux=Charge/permittivity (in a closed surface)
If h = 0.5 L, then I would just divide the flux by six. But I don't know where to go from here...
Contemplate the relevant equation you provided!
but how should I contemplate it? The surface is an open surface, and the flux is asymmetrical.
Ah, sorry. I jumped to the (incorrect) assumption that it was a square box, not just a square surface.
I suppose you'll have to integrate E.dS over the surface to determine the total flux.
Actually, I just solved it no integral necessary :D. Basically, I imagined the surface as part of a cube, and the cube surrounded by a sphere. Connecting the four corners of the surface to the electron in the center creates a square pyramid with base length L X L and height 0.05 L. I used the formula 4*arcsin((a^2)/(a^2+4*h^2)) to find the solid angle, and divided it by 4pi, the total solid angle. I multplied the resulting value by the total flux of the cube. It seems that solid angles play an important part in Gauss's law.
This was all tiring, but totally worth it when I got the correct answer.
Nicely done.
