Force exerted on block B by Block A when being pushed on a frictionless surface
  • Thread starter Thread starter yashboi123
    Block Force
The discussion revolves around the forces exerted between two blocks on a frictionless surface, specifically focusing on the force that Block A exerts on Block B. The subject area includes concepts from dynamics and Newton's laws of motion.
  • Participants explore the reasoning behind using the mass of Block B to determine the force exerted by Block A, questioning the role of Block B's inertia and mass in this context. There are suggestions to draw free body diagrams to clarify the forces acting on each block.
The discussion is active with participants raising questions about the assumptions involved in the problem, particularly regarding the relationship between the masses of the blocks and the forces acting on them. Some guidance on using free body diagrams has been mentioned, indicating a productive direction in the conversation.
There is an implicit assumption about the frictionless nature of the surface and the interaction between the two blocks, which may influence the analysis of forces. The varying mass of Block B is also a point of consideration in understanding the dynamics at play.
yashboi123
Boxes A and B are in contact on a horizontal, frictionless surface (Figure 1). Box A has mass 25.0 kg and box B has mass 7.0 kg . A horizontal force of 100 N is exerted on box A \.
F = ma
I was just wondering why you would do
mB * a
to get the force A is exerting on B instead of
mA * a
If B were not there, would there be any force on that side of A? If B was super small, would it take much force to keep it accelerating along with A? What if it was very large? So, you see, B’s inertia is the reason there is any force between B and A and B’s mass is what you need to figure out how big the force is.
In problems like this always draw the free body diagrams and show the forces on each block separately. Then you can write the equations and they should makes sense.
yashboi123 said:
why you would do
mB * a
mA * a
Because A's acceleration is a consequence of the two forces on A, whereas there is only one force on B.
