Force induced on a point charge by two conducting planes
The problem involves a point charge located near two grounded conducting planes that intersect at right angles. Participants are tasked with determining the force acting on the charge, considering induced charges on the planes and the boundary conditions for potential.
  • Participants discuss the concept of induced charges on the conducting planes and explore the idea of replacing the planes with an equivalent system of point charges. There is consideration of how to maintain boundary conditions and the implications of charge placement.
Some participants are providing guidance on the setup of the equivalent charge system and discussing the calculations of forces. There is an ongoing exploration of different interpretations of the problem and calculations, with no explicit consensus reached on the final results.
Participants are navigating potential confusion regarding the factors in their force calculations and the arrangement of equivalent charges. There are indications of differing approaches to calculating forces based on the arrangement of charges and their contributions.
Strawberry
A point charge q is located in the xy plane near two grounded conducting planes intersecting at right angles as shown in the Figure. The z axis lies along the line of intersection of the planes. Find and justify (mathematically show) the force acting on this charge q (both direction and magnitude should be specified).
1. Think about how much charge would be induced on the conducting planes.
2. What would be the potential on the conducting planes (This is the boundary condition) and what can you do to maintain such a condition?
3. If a different method was used for your calculation, please describe the method.
A .doc file containing the question and a diagram is attached.
I'm assuming a negative charge is induced on the conducting planes, but beyond that I seriously have no clue. Absolutely any help whatsoever would be greatly appreciated.
I found a website with a related problem by google searching "force point charge conducting plane." It's the davidpace one ( I can't link to websites yet). Can I do basically the same thing with each conducting plane individually and use vector addition to find the resultant force?
Okay, after looking this over more, I'm thinking that replacing the conducting plates with three point charges would make an equivalent system. Using the plates as axes, there would be mirrored negative charges across the x, y, and y= -x axes. So charges like a square, with one corner being an opposite charge. After that, the force calculation would just be a system of point charges. Is this the right idea?
Hi strawberry,
That is the right idea; however I believe you need two corners to be oppositely charged that of the original point charge. Do you see why? Which two corners would you choose?
Thank you very much for your response alphysicist. I took your advice and I think I have the right answer.
The equivalent charge system is like a square with opposite corners having the same charge, I think.
(-q) - - - q
q - - - -(-q)
Taking V to be the sum of V for each charge at the origin, (0,a) and (a,0) I found V to be 0 along the original conducting plates. After that I used F = k [(q1*q2)/r^2] r to find the force of each equivalent charge on the initial charge. I ended up with three forces, then added them together.
My final result was F = k* (q^2 / a^2) * [ sqrt(2) - 4 ]/4 * i + [ sqrt(2)-4)/4 ] * j ]
Hi Strawberry,
It looks to me like you are missing a factor of (1/4). Am I just reading your final result wrong?
Well I have everything divided by 4, should it be divided by 16?
Is this more clear?
F = k* (q^2 / a^2)/4 * [ sqrt(2) - 4 ] * i + [ sqrt(2)-4) ] * j ]
I'm getting something different from that. For example, for the x direction, I am getting
[tex] F = \frac{k q^2}{(2a)^2}[/tex]
for the particle at the upper left corner, and
[tex] F = \frac{kq^2}{(\sqrt{2}\cdot 2a)^2} \cos(45^{\circ})[/tex]
for the x component from the particle at the lower left corner. I then subtract those. Is that what you got? I don't think that gives the answer for the x component that you stated. Or am I thinking of it wrongly?
