Force Question -- Solidworks model of a pulley system
The discussion centers on simulating a pulley system in SolidWorks, specifically addressing the impact of doubling the force and adjusting the dimensions of the pulley. The original hypothesis suggested multiplying all dimensions by the cubed root of 2 to maintain simulation results, assuming that doubling the force and volume would yield consistent outcomes. However, calculations revealed that torque increases significantly due to the changes in both force and radius, leading to unexpected simulation results. The correct torque calculation indicates an increase by a factor of approximately 2.5, highlighting the importance of precise dimensional adjustments in simulations.
  • SolidWorks simulation tools
  • Understanding of torque calculations
  • Knowledge of material strength principles
  • Familiarity with dimensional analysis in engineering
  • Explore SolidWorks simulation settings for accurate force and torque analysis
  • Study the relationship between force, radius, and torque in mechanical systems
  • Learn about the effects of dimensional changes on structural integrity
  • Investigate advanced materials and their behavior under varying forces
Mechanical engineers, SolidWorks users, and students studying physics or engineering principles related to force and torque in mechanical systems.
Elijah Carstens
Hello Everyone,
I'm currently making simulations in Solidworks and am confused.
I have to double the force on a pulley and change the dimensions from the original pulley, in order to withstand the new force.
My hypothesis:
If I multiply all the dimensions by the cubed root of 2, then my volume will double and the results of both simulations will remain the same, because I doubled the force and the volume of the second experiment.
Does that make sense?
I figured if the volume of the object doubles along with the amount of force, then the results should remain the same.
When i ran the simulation, it didn't go as planned.
Why?
Thank You so much!
Elijah Carstens said:
My hypothesis:
Try to express what you're doing in terms of physics, for those who might not know anything about "Solidworks".
Sorry I seem to have accidentally deleted my first attempt to post this so...
Strength of materials isn't really my field but consider the torque calculation..
Torque = force * radius
You are doubling the force and increasing the radius by sqrt 2 so the torque increases by about 2.8.
Perhaps that doesn't matter?
Maybe clarify what you mean. My math was dividing the new amount of force (800N), by the original amount (400N).
That's how I got 2. I needed that number in order to find what to multiply the original dimensions by.
3√2 * (original dimensions of pulley)
Sorry I made a mistake in my post above. I should have used 3√2 instead of sqrt.
If you are increasing all dimensions by 3√2 then does that also includes the radius?
When you refer to "force" I assume you mean the difference in tension between the two sides of the belt (eg the force used to calculate the torque on the pulley)?
Putting these two together you can calculate that the torque is increasing by a factor of...
(New Radius/Old Radius)*(New force/Old force) = 3√2 * 800/400 = 2.5
Perhaps by "force" you mean something different?
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 22 ·
