Solved: Forced Vibrations Homework: Using Arctan
  • Thread starter Thread starter vanceEE
    Vibrations
The discussion revolves around a forced vibrations problem described by a second-order differential equation involving mass, damping, and stiffness parameters. The original poster attempts to express the particular solution using the arctan function for simplification.
  • Exploratory, Mathematical reasoning
  • Participants discuss the transformation of the solution into a form involving the arctan function. There are attempts to relate the terms of the solution to a cosine function with a phase shift.
Some participants have provided links to resources that may aid in understanding the transformation. There is an ongoing exploration of the correct expression for the phase angle, with one participant questioning a factor in the original formulation.
Participants are navigating through the implications of using arctan in the context of forced vibrations, with specific attention to the parameters involved in the equation. There is a noted discrepancy regarding the phase angle calculation that remains to be resolved.
vanceEE
$$ M \frac{d^2x}{dt^2} + c\frac{dx}{dt} + kx = F_{0}cos \omega t $$
$$x(t) = asin\omega t + bcos \omega t $$
$$ a = \frac{\omega c F_{0}}{(k-\omega^2M)^2 + \omega^2c^2} $$
$$ b = \frac{(k-\omega^2M)F_{0}}{(k-\omega^2M)^2 + \omega^2c^2} $$
$$ x_{0}(t) = \frac{F_{0}}{(k-\omega^2M)^2 + \omega^2c^2} [\omega c sin \omega t + (k-\omega^2M)cos \omega t] $$
How can I use arctan to write this particular solution in a more useful form?
LCKurtz said:
Thank's for the link, it was really helpful!
So ##[\omega sin \omega t + (k-\omega ^2 M) cos \omega t] \equiv [(Rcos\phi)cos\omega t + (Rsin\phi)sin \omega t] ## by the sum-difference formulas
Therefore,
$$\frac{F_{0}}{(k-\omega^2M)^2 + \omega^2c^2} [\omega c sin \omega t + (k-\omega^2M)cos \omega t] $$ $$\equiv \frac{F_{0} R cos (\omega t -\phi)}{R^2} $$ $$\equiv \frac{F_{0}}{√((k-\omega^2M)^2 + \omega^2c^2)} [cos \omega t - \phi] $$ where $$ \phi = \arctan (\frac{\omega}{k-\omega ^2M}) $$
Right?
You forgot a factor of ##c##. The phase angle should be
$$\phi = \arctan\left(\frac{\omega c}{k-\omega^2 M}\right).$$
  • · Replies 23 ·
