Forces and wrecking ball Question
  • Thread starter Thread starter yosup231
    Ball Forces
The discussion focuses on solving a physics problem involving a 1240 kg wrecking ball subjected to a horizontal force of 5480 N. The first part requires calculating the angle the wrecking ball makes with the vertical, which is determined to be approximately 24.27 degrees using trigonometric relationships. The second part involves finding the tension in the supporting cable, which is calculated as the resultant force of the weight and applied force, yielding a value of 13330.457 N. Participants clarify the importance of understanding the forces acting on the wrecking ball and the application of Pythagorean theorem in this context.
  • Understanding of Newton's laws of motion
  • Knowledge of trigonometric functions and their applications
  • Familiarity with vector addition and resultant forces
  • Basic principles of equilibrium in physics
  • Study the application of Newton's second law in dynamic systems
  • Learn about vector decomposition and how to resolve forces into components
  • Explore the principles of tension in cables and their calculations
  • Investigate the role of friction and equilibrium in static and dynamic scenarios
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of force and tension calculations in real-world applications.
yosup231
hey I am new here and i need help with this problem:
a 1240 kg wrecking ball is pulled back with a horizontal force of 5480 N before being swung against the side of a building. a) What angle does the wrecking ball make with the vertical when it is pulled back? b) What is the tension in the ball's supporting cable when it is at this angle?
If you're new here then you may not have noticed the requirement that you show some of your own work before seeking help. So, tell us what you've done so far! :)
sorry i wasn't aware
well i think i have to do ((1240N)(9.8m/s^2))/cosx)=5480 and then try to solve for the angle but that can't be what I am suppose to do since that since the number i would be doing cosine inverse for is greater than 1 and for part b I am just not sure
There are three forces acting on the ball. Ultimately, you want to find the tension in the cable. Since all three forces add to zero, you will need to find the resultant vector of the weight (vertical) and the applied force (horizontal) displacing the ball. What angle does the resultant force make with respect to the vertical? It will help to draw a picture!
For part (b), the tension exactly balances the other two forces. You should be able to determine the magnitude of the vector resulting from adding the force of the weight (vertical) with applied force (horizontal).
im still not sure
so for a would i do (1240 kg)(9.8m/s^2)=12152
then (5480^2)+(12152^2)=resultant^2 which would have the res= 13330.457
then cosx=12152/13330.457... x= 24.27 degrees
and then for part b would it just be 13330.457
Is this right or am I WAY off
Looks good!
But wait up. To pull the ball back in the first place, you have to apply a force greater than the weight of the wrecking ball, no?
So, 1240*-9.8 = -12152N
And, since you are only applying 5480 N, -12152 + 5480 is -6672 (which would be the force holding the wrecking ball in place (something like friction, since the ball is hanging down). Therefore, the angle would be 90 (vertical).
Also, realize that this is not going to be a right triangle (you're using Pythagoreans theorem). It's going to be a curve, or arc.
Correct me if I'm wrong!
Thanks
No. You do not have to apply a force equal to the weight of the ball to displace it from its equilibrium point. Most of the weight is being supported by the cable.
Also, the problem specifically stated that the applied force is horizontal. The weight is directed vertically. Therefore, Pythagoras works just fine.
Thanks
Thanks for your help
  • · Replies 16 ·
