I Forces between two straight conductors
  • I
  • Thread starter Thread starter LogarithmLuke
    Conductors Forces
The discussion focuses on understanding the forces between two straight conductors carrying currents. When currents flow in the same direction, the conductors attract each other, while opposite currents result in a repulsive force. The right-hand rule is essential for determining the direction of these forces, but users express difficulty in applying it. The conversation suggests breaking down the problem into two parts: the magnetic field created by one wire and the Lorentz force experienced by the other. Visualizing the magnetic field patterns for both scenarios clarifies the attractive and repulsive interactions between the conductors.
LogarithmLuke
Hi, I am having trouble figuring out how the forces work between two straight conductors with currents going through them. I know that when the currents go the same way, the forces are attractive, and when the currents go opposite ways, the forces are repelling. I know one has to use the right hand rule, but i just can't figure out how to do it to get it right.
Could someone help clear this up?
BvU said:
Hi LL,
Let me give it a try. I find this easiest if split up in two parts:
  1. Magnetic field of a current carrying wire (Ampere's law, Biot-Savart)
  2. Lorentz force on current in a wire (the other one...)
Im aware of what the magnetic fields around the wires look like, the trouble comes with finding the direction of the forces between to conductors.
That's exactly what I'm avoiding by first establishing a B field from wire 1 -- after which I can forget wire 1. Wire 2 then experiences a Lorentz force in that B field.
Hyperphysics in fact does it the same way (1 = left, 2= right wire)
can you sketch the field patterns for each wire. Can you sketch the resultant field pattern for 2 wires when the currents are in the same direction and in opposite directions. In the same direction the combined field is (visually) attractive.
In opposite directions the combined field is (visually) repulsive.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
