Forces in 3-D: Homework Solutions
  • Thread starter Thread starter VectorA
    forces
The discussion revolves around a problem involving forces in three-dimensional space, specifically focusing on the relationships between points and vectors in a static system. Participants are exploring the components of forces and moments related to points A, B, C, and D, with an emphasis on understanding how the unknown distance L affects the configuration.
  • Participants are attempting to break down the forces into components and are questioning the alignment of points C and D in relation to the unknown distance L. There are discussions about taking moments around different axes and the implications of having multiple unknowns in the equations.
The conversation is ongoing, with participants providing insights into the relationships between the vectors and discussing the complexity of the problem. Some have offered guidance on how to approach the moment calculations and the need for clarity in the vector expressions.
There is an acknowledgment of the unknowns in the problem, particularly the distance L and the forces at points C and D. Participants are also navigating the challenge of expressing their work clearly, with some expressing confusion about the calculations and vector relationships.
VectorA
I am kind of confused as to why CD will be a function of L.
For BE i think it is ( -4i + 8j - 8k)
For CD i think it is (6j - 8k) ---> I don't think there is any i value because they seem to be lined up together. I think i am not understanding the question properly. Is it that D is not lined up with C and so there will be an i value?
Well, the distance L is unknown, so how can you be certain the points C and D are aligned in the x-direction? What if L can move back and forth parallel to the x-axis?
Ok that makes sense so L is unknown and it can be anything, which is later confirmed in part(b). So Can you please help me in part(b) ?
You want the value of L for which the system is static. What equations can you write down for static systems?
First i broke BE into components and i got 0.33BE(i) + 0.66BE(j) - 0.66BE(k) ----------(1)
Then there is a ball and socket joint at A so it is broken into components Ax, Ay, Az ------------ (2)
Force at P = 5kn so it is simply 5 Kn (j) ----------- (3)
Problem arises at CD. This is what i think looks like when you break CD into components given that L is unknown
-------------- (4)
Now after that I would take x component from each of the above equations and combine them together, same with y and same with z. This way i would have x components of all the equations separated in one equations and then same with y and z and i can set the coefficient equal to zero and try solve for it but there are too many unknowns.
Next step is to take moment around A and set it to zero but again the CD is the problem as there are too many unknowns :(
above are the equations that i can think of.
Which axis through A?
Other than L and the tension in CD, what unknowns do you have in that equation?
Well, i also don't have BE to begin with. My main problem that i am stuck at is that neither do i have CD nor L. I am sorry but this problem is really confusing me :(
Can you please give me more hint in order to solve it?
Right, you have three unknowns, if you avoid involving the forces at A. To keep those forces out of it, you are taking moments about A. But you haven't answered my question about axis. Which axis through A are you taking moments about? What are the choices?
I am sorry i don't quite understand the question here. I take the distance from A to the B and then do a cross product with the force BE. Take distance from A to C and then do a cross product of that distance with the force CD. Take distance from A to P and do a cross product of it with 5Kn.
Ok, that's fine. So you get a 3D vector equation. That's equivalent to 3 scalar equations, and you have three scalar unknowns.
I can take moment about BE and P but i can't around CD. Even if i do take moment around CD there are more than one unknowns.
I agreed that what you did in taking those cross products was fine. (It's equivalent to what I was thinking of in terms of taking moments about three axes through A.)
That one vector statics equation should give you all you need.
Please post it.
First i am posting the components of each force, that is BE, CD and P
Moment around P = -40(i) + 15(k)
Moment around BE = -5.336(i) + 2.64(j)
Now moment around CD is a bit complicated.
Posting your working as images is frowned upon. It makes it hard for those making comments to point out which equations or steps they are commenting on. Please learn to use LaTeX.
I am really sorry. This is my first day here at the forums.
You mean the moment of the force at P about A.
Again, you mean the moment of the tension in BE about A, yes? And you need the magnitude of that tension as a factor.
Why is it any more complicated? Just take the cross product of vector CD with either AC or AD.
well you see the components of CD are a little different than BE or P because CD has L. As you can see in the picture above the components involves fraction and square root. I took the moment and this is what i get.
Again i am really sorry for this picture. I will learn LATEX with time.
So now i am confused on how to solve this further.
First, we need to get the correct expression for the vector CD. What you had in post #5 is wrong. How do the x coordinates of C and D compare?
Next, to make the algebra simpler, invent a symbol for 1/(length of CD).
Now you should be able to type your working in without having to use LaTeX.
(I also advise against plugging in any actual lengths, but instead invent symbols for all the given distances. It makes it much easier to follow the working and minimises errors.)
They are the same?
VectorA said:
They are the same?
No, look again. Please post what you think the vectors AC, AD look like.
AD: L(i) + 6(j)
AC: 6(i) + 8(k)
VectorA said:
AD: L(i) + 6(j)
AC: 6(i) + 8(k)
Right, so take the difference to find the vector CD.
I am so sorry for asking stupid questions but does the difference look like this?
6-L(i) + 6(j) + 8(k)
No, you have some signs wrong.
To calculate CD from AC and AD, which do you subtract from which?
AC - AD
6-L (i) + 8(k) - 6(j)
is my answer correct?
VectorA said:
AC - AD
Ummm, no. We're agreed that "CD" means "the vector from C to D", yes? If the above were correct, we'd have CD+AD=AC. Does that look right?
16K
