Why Does One Side of a Belt Fall When Hung Unevenly?
  • Thread starter Thread starter sgstudent
    Forces String
The discussion centers on the mechanics of why one side of a belt falls when hung unevenly on a towel holder. Participants explain that the imbalance in weight creates a net downward force on the heavier side, while the lighter side experiences tension that pulls it upwards. The towel holder does not exert an upward force sufficient to counteract the sliding motion caused by the uneven weight distribution. A free body diagram is suggested as a useful tool for visualizing the forces at play.
  • Understanding of basic physics concepts, specifically tension and forces.
  • Familiarity with free body diagrams for visualizing forces.
  • Knowledge of friction and surface interactions between objects.
  • Basic principles of equilibrium and net forces in static systems.
  • Study the principles of tension in ropes and cables.
  • Learn how to create and interpret free body diagrams.
  • Research the effects of friction on inclined surfaces and hanging objects.
  • Explore the concept of equilibrium in static systems and how it applies to everyday objects.
Physics students, educators, and anyone interested in understanding the mechanics of forces and equilibrium in everyday scenarios.
sgstudent
I thought about this when hanging my belt on to the towel holder. If i put too much of the belt on one side, that side would fall down. Why does this happen? Shouldn't the towel hanger just put up an equal force to the total weight of the belt keeping it up?
I understand a little when we say that the towel hanger acts as a pulley so the direction of the force can be changed but i still don't get why an upwards force isn't present to hold the belt up actually.
Thanks for the help :)
It's not that the hanger isn't exerting enough force on the belt to hold it up. A physicist would rely on his powers of observation to formulate a theory.
Ask yourself, why does the belt fall if the amount of weight isn't balanced between the two sides? What happens where the belt is resting on the holder? Is there anything on the holder which can resist the motion of the belt if, for whatever reason, the belt starts moving? Can the belt be placed on the holder in another way such that it will not slip off?
Hi thanks for the reply :)
Using the tension and forces we learned, it would be because one side of the rope has more weight than the other so it would have a net downwards force while the other side would have a tension that would pull the lesser weight up. But while these 2 processes occur, does the holder exert an upwards force too?
Thanks for the help
Indubitably. Draw a free body diagram of the belt and the holder.
Look, your holder is not magic. The belt and the holder both probably have slick surfaces. The belt falls off the holder, if it is not evenly hung, because the unbalanced weight causes the belt to slide.
  • · Replies 30 ·
  • · Replies 23 ·
