Forces Problem Involving A Tree Branch acting as a monkey's pulley
The discussion revolves around a physics problem involving a 10 kg monkey climbing a massless rope over a frictionless tree limb, which is connected to a 15 kg package on the ground. The least acceleration required for the monkey to lift the package is calculated to be 4.9 m/s². After the package is lifted, when the monkey holds onto the rope, its acceleration is 2.0 m/s² upward, and the tension in the rope is determined to be 120 N. The calculations utilize Newton's second law and the relationship between tension and weight forces.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of weight calculation (weight=mg)
  • Familiarity with tension in ropes and forces acting on objects
  • Ability to analyze systems with multiple interacting bodies
  • Study the concepts of tension in ropes and its applications in physics problems
  • Learn about systems of equations in dynamics involving multiple bodies
  • Explore advanced topics in mechanics, such as pulleys and frictionless systems
  • Review examples of similar physics problems to reinforce understanding
Students studying physics, particularly those focusing on mechanics, as well as educators looking for illustrative examples of force interactions in systems involving pulleys and tension.
brendan3eb
A 10 kg monkey climbs up a massless rope that runs over a frictionless tree limb and back down to a 15 kg package on the ground. (a) What is the magnitude of the least acceleration the monkey must have if it is to lift the package off the ground? If, after the package has been lifted, the monkey stops its climb and holds onto the rope, what are (b) the magnitude and (c) the direction of the monkey's acceleration, and (d) what is the tension in the rope?
weight=mg
F=ma=T-mg
I was able to get part A with the following work:
Sum of forces on monkey = MA=T-Mg
Sum of forces on banana box = ma=T-mg
when the package goes from being on the ground to being lifted off the ground it's acceleration will change from 0 to some number, thus the minimum rope tension required will be just greater than T when a=0
ma=T-mg
a=(T-mg)/m
0=(T-mg)/m
T=mg=(15 kg)(9.8 m/s^2)=147 N
MA=T-Mg
A=(T-Mg)/M
A=[147 N - (10 kg)(9.8 m/s^2)]/10 kg = 4.9 m/s^2
I should also mention that I have the answers from the back of the book:
(a) 4.9 m/s^2
(b) 2.0 m/s^2
(c) upward
(d) 120 N
So I got part A right, but my attempts at parts B-D did not work. Here is what I tried and my results:
Since the monkey is no longer pulling on the rope, the accelerations of the monkey and the box should have the same magnitude but opposite directions.
MA=T-Mg
T=Mg+MA
mA=T-mg
T=mA + mg
set the two Ts to equal each other
Mg+MA = mA + mg
(10 kg)(9.8 m/s^2) + (10 kg)A = (15 kg)A + (15 kg)(9.8 m/s^2)
when you solve, you get A=9.8 m/s^2
I even tried changing the signs around for the two different equations to see if that would give me the right answer, but no luck. Any help would be much appreciated :)
MA=T-Mg
T=Mg+MA
mA=T-mg
T=mA + mg
Careful with signs. If the monkey's acceleration is +A, what must be the box's acceleration?
Ah! Thank you, I was thinking about that but with regard to mg. I was changing mg to be positive or negative and was getting an acceleration of 2 m/s^2
Once again, thanks! :P
weight=mg
F=ma=T-mg
ma=T-mg
a=(T-mg)/m
0=(T-mg)/m
MA=T-Mg
A=(T-Mg)/M
(a) 4.9 m/s^2
(b) 2.0 m/s^2
(c) upward
(d) 120 N
MA=T-Mg
T=Mg+MA
mA=T-mg
T=mA + mg
Mg+MA = mA + mg
Can someone please explain more on the bold part ? I don't understand it
When the monkey hauls on the rope, if tension in the rope exactly equals the package's weight, the package will barely leave the ground. If he exerts a force greater than the weight of the package, the package will move upwards.
weight=mg
F=ma=T-mg
ma=T-mg
a=(T-mg)/m
0=(T-mg)/m
MA=T-Mg
A=(T-Mg)/M
(a) 4.9 m/s^2
(b) 2.0 m/s^2
(c) upward
(d) 120 N
MA=T-Mg
T=Mg+MA
mA=T-mg
T=mA + mg
Mg+MA = mA + mg
The monkey stops climbing, but still holds on to the rope, so will be pulling on the rope due to the effects of gravity on the monkey.
For(b) there is the weight force of a 10kg monkey pulling one way, and the weight force of a 15 kg package pulling the other way.
I see that as the net force of a 5kg weight acting on a 25kg system.
A weight force of a 5kg mass, acting on 5 kg gives acceleration g
A weight force of a 5kg mass acting on 25 kg should give acceleration g/5
The tension in the rope will exceed the individual weight force of the 10kg monkey by enough to cause that acceleration.
Thanks for explaining this to me.
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 22 ·
  • · Replies 40 ·
