Formula for fictitious moments
This discussion focuses on the formulation of fictitious moments experienced by solid bodies in non-inertial frames, building on established concepts of fictitious forces such as Euler, centrifugal, and Coriolis forces. The formulas for these forces are provided, including Euler force (FE = -m ⋅ dΩ/dt × OP), centrifugal force (FCe = -m ⋅ Ω × (Ω × OP)), and Coriolis force (FCo = -m ⋅ 2Ω × V). The author suggests using the action principle and Lagrangian mechanics to derive fictitious moments, particularly in the context of gyrocompasses, referencing both Wikipedia and personal lecture notes for further exploration.
  • Understanding of fictitious forces in non-inertial frames
  • Familiarity with Lagrangian mechanics
  • Knowledge of inertia tensors and their application in solid mechanics
  • Basic concepts of rotational dynamics
  • Study the derivation of fictitious forces in non-inertial frames
  • Explore Lagrangian mechanics with a focus on center-mass coordinates
  • Research the theoretical treatment of gyrocompasses and their applications
  • Examine inertia tensors and their role in calculating fictitious moments
Students and professionals in physics, mechanical engineering, and applied mathematics, particularly those interested in dynamics and the effects of non-inertial reference frames on solid bodies.
taalf
Hi All,
Everyone knows so called "fictitious" forces, also known as "inertial" forces. They are forces felt by some mass point placed in a non-inertial frame. For example: a ball in a moving car or in a carousel.
Maybe most intuitive fictitious forces are centrifugal forces, but there are also Euler forces and Coriolis forces. Formulas for such forces are well known (bold means "vector"):
Euler force: FE = -m ⋅ dΩ/dt × OP
Centrifugal force: FCe = -m ⋅ Ω × (Ω × OP)
Coriolis force: FCo = -m ⋅ 2Ω × V
with:
m the mass of the point,
Ω the rotation vector of the non inertial frame,
OP the position of the point in the non inertial frame,
V the velocity of the point in the non inertial frame.
Know, consider the object is not a mass point, but some solid with a given inertia tensor:
___|Ixx Ixy Ixz|
I = |Iyx Iyy Iyz|
___|Izx Izy Izz|
This solid, put in a non inertial frame, should not only feel fictitious forces, but also fictitious moments.
The question is: how to formulate them?
That's a really interesting question. I guess it's quite complicated. That's why I right away would use the action principle and write down the Lagrangian using center-mass coordinates and Euler angles between body-fixed and space-fixed Cartesian bases but with the space-fixed frame as a non-inertial (rotating) reference frame.
A special case of this is the theoretical treatment of the gyrocompass, which you can find in the Wikipedia (although I found this more complicated than necessary):
https://en.wikipedia.org/wiki/Gyrocompass
My own attempt to explain it, you can find in my lecture notes on mechanics, which are, however, in German (p. 129ff)
https://th.physik.uni-frankfurt.de/~hees/publ/theo1-l3.pdf
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 22 ·
