Formula for trajectory also applicable to decelerating bodies?
The formula d=0.5(g)(t^2) is specific to free-falling objects under gravity and cannot be applied to decelerating bodies like cars without considering friction. For decelerating objects, alternative equations are available, such as d = v_i t + 0.5a t^2, which require knowledge of initial speed and acceleration. These formulas are valid only when acceleration is constant, unlike the gravitational formula which assumes a specific acceleration of 9.8 m/s². While deceleration can be conceptually compared to upward motion, the rates differ significantly. Therefore, appropriate formulas must be used for accurate calculations in deceleration scenarios.
ionowattodo
The formula that is applied to falling objects with disregard to any exterior forces except gravity is : d=0.5(g)(t^2)
Can it also be applied to decelerating bodies, such as cars, with disregard to friction?
Such as a car with an initial velocity slowing down to 0 m/s over a distance of 50 meters.
No, that formula only works for a body in free fall, starting from rest, in Earth's gravity (or equivalent).
For other accelerating or decelerating objects, there are various formulas you can use:
d = v_i t + \frac{1}{2}a t^2
if you know initial speed and acceleration
d = v_f t - \frac{1}{2}a t^2
if you know final speed and acceleration
d = \frac{(v_f + v_i)t}{2}
if you know initial and final speeds and time
d = \frac{v_f^2 - v_i^2}{2a}
if you know initial and final speed and acceleration
Of course, all these are only applicable when the acceleration is constant.
Can't you substitute gravity for deceleration?
Basically if you turn a deceleration car to it going upwards, it's the same as a thrown ball except with different deceleration rates
Well, yes, it's the same, but the rate of acceleration/deceleration is not g for a car. The formulas I gave in my post work for any constant acceleration/deceleration. But the one you were originally asking about is what you get when the acceleration happens to be equal to 9.8 m/s^2 (and the initial speed is zero).
I built a device designed to brake angular velocity which seems to work based on below, i used a flexible shaft that could bow up and down so i could visually see what was happening for the prototypes. If you spin two wheels in opposite directions each with a magnitude of angular momentum L on a rigid shaft (equal magnitude opposite directions), then rotate the shaft at 90 degrees to the momentum vectors at constant angular velocity omega, then the resulting torques oppose each other...
  • · Replies 16 ·
  • · Replies 33 ·
