Fourier Series Coefficients of an Even Square Wave
The discussion focuses on calculating the Fourier series coefficients for an even square wave function defined over the period \( T_0 = 4 \). The coefficients \( a_0 \), \( a_n \), and \( c_n \) were derived using the appropriate integrals, with \( a_0 = \frac{1}{2} \) and \( a_n = \frac{2}{\pi n} \sin\left(\frac{\pi n}{2}\right) \). The exponential form coefficients \( c_n \) were also discussed, with the need to consider both positive and negative harmonics. The participants emphasized the importance of understanding the difference between trigonometric and exponential forms of Fourier series.
  • Understanding of Fourier series and their coefficients
  • Knowledge of trigonometric functions and integrals
  • Familiarity with complex numbers and Euler's formula
  • Basic MATLAB skills for plotting functions
  • Learn how to derive Fourier coefficients for different periodic functions
  • Study the application of Euler's formula in converting trigonometric to exponential forms
  • Explore MATLAB plotting techniques for visualizing Fourier series
  • Investigate the implications of harmonic analysis in signal processing
Students and professionals in electrical engineering, applied mathematics, and physics who are working with signal analysis and Fourier series. This discussion is particularly beneficial for those seeking to deepen their understanding of Fourier analysis and its applications in various fields.
Captain1024
Link: http://i.imgur.com/klFmtTH.png
a_0=\frac{1}{T_0}\int ^{T_0}_{0}x(t)dt
a_n=\frac{2}{T_0}\int ^{\frac{T_0}{2}}_{\frac{-T_0}{2}}x(t)cos(n\omega t)dt
\omega =2\pi f=\frac{2\pi}{T_0}
Firstly, x(t) is an even function because x=1/2 when t=-t_0 and t=t_0. Therefore, all bn coefficients of the Fourier series will be zero.
T_0=4, \omega =\frac{2\pi}{4}=\frac{\pi}{2}, t_0=1
a0 is basically the average value of x(t) over the period. By inspection a0 = 2/4 = 1/2
It makes sense to me to split up x(t) into regions:
x(t) = 0 when \frac{-T_0}{2}<t<-t_0, t_0<t<\frac{T_0}{2}
x(t) = 1/2 when t=^+_-t_0
x(t) = 1 when -t_0<t<t_0
a_n=\frac{2}{T_0}[\frac{1}{2}\int ^{-t_0}_{-t_0}cos(n\omega t)dt+\int ^{t_0}_{-t_0}cos(n\omega t)dt+\frac{1}{2}\int ^{t_0}_{t_0}cos(n\omega t)]
=\frac{2}{n\omega T_0}(1+[sin(\frac{\pi}{2}nt)]^{t_0}_{-t_0})
=\frac{2}{n\omega T_0}[1+(sin(\frac{\pi}{2}nt_0)-sin(\frac{-\pi}{2}nt_0)]
=\frac{2}{n\omega T_0}[1+2sin(\frac{\pi n}{2})]
a_0=\frac{1}{2}, a_1=\frac{3}{\pi}, a_2=\frac{1}{2\pi}, a_3=\frac{-1}{3\pi}, a_4=\frac{1}{4\pi}, a_5=\frac{3}{5\pi}, a_6=\frac{1}{6\pi}
(1) asks for coefficients in exponential and trigonometric forms. Are the coefficients I calculated above correct for either of those forms? How do I get the coefficients in the other form?
(2) & (3) ask for a MatLab plots. We haven't gone over any MatLab in class. If someone could point me in the right direction I think I can figure it out. I've worked with MatLab in the past.
Thanks for your time.
-Captain1024
You should be able to answer the first question yourself, or are you really just blindly using formulas with no idea why? You really should know what "exponential form" and "trigonometric form" mean.
I probably knew the difference at some point in the past, but I could use a refresher.
I believe the answers i have calculated are in the trig form. To get the exponential form, I'm thinking I will need to use Euler's formula. Is this correct?
Complex coefficients c_n (exponential form?)
c_0 will remain the same value of 1/2
c_n=\frac{1}{T_0}\int ^{\frac{T_0}{2}}_{\frac{-T_0}{2}}x(t)\mathrm{exp}(-j\omega nt)dt
=\frac{1}{T_0}(1+\int ^{t_0}_{-t_0}e^{-j\omega nt}dt)
=\frac{1}{T_0}(1+[\frac{-1}{j\omega n}e^{-j\omega nt}]^{t_0}_{-t_0})
=\frac{1}{T_0}(1+(\frac{-1}{j\omega n})[e^{-j\omega nt_0}-e^{j\omega nt_0}])
When \omega=\frac{\pi}{2}, T_0=4, t_0=1;
c_1=\frac{\frac{\pi}{4}+1}{\pi}, c_2=\frac{1}{4}, c_3=\frac{\frac{3\pi}{4}-1}{3\pi}, c_4=\frac{1}{4}, c_5=\frac{\frac{5\pi}{4}+1}{5\pi}, c_6=\frac{1}{4}
Am I on the right track here?
No, your computed ##c_n## are incorrect; I don't know where on Earth you got the formulas you are using.
Besides, the Fourier series in exponential form is ##f(t) = \sum_{n=-\infty}^{\infty} c_n e^{j \omega n t}##, so you need to consider terms with ##n < 0## also.
Fine. Based on the reply's to this thread thus far, I know next to nothing about how to solve this problem. I accept this.
So, if you are willing, I would like to solve this problem together step by step.
Based on what I read at this link: Any periodic function may be expressed as an infinite series of the form x(t)=\sum ^{\infty}_{m=0}a_mcos(\frac{2\pi mt}{T})+\sum ^{\infty}_{n=1}b_nsin(\frac{2\pi nt}{T}), where a_m and b_n are real constants. This series is called a Fourier series.
Now, after reading the same website, I believe I need to use the following equations in order to find the real coefficients up to the 7th harmonic:
a_0=\frac{1}{2}\int ^{T}_{0}x(t)dt
a_m=\frac{2}{T}\int ^{T}_{0}x(t)cos(\frac{2\pi mt}{T})dt
b_n=\frac{2}{T}\int ^{T}_{0}x(t)sin(\frac{2\pi nt}{T})dt
Am I right so far?
Am I right so far?
No, not really, unless you re-define your function as
$$ x(t) = \begin{cases}
1 & 0 < t < t_0\\
0 & t_0 < t < T-0-t_0\\
1 & T_0-t_0 < t < T_0
\end{cases}
That would be your original function, but built on a base ##[0,T_0]##. It would be much easier to use the original definition of ##x(t)## based on ##[-T_0/2,T_0/2]## , but to use the Fourier series formulas that are appropriate to that case.
Note: you had done it correctly in your first post, when you computed the ##a_n## and ##b_n## for the Fourier series with sines and cosines. Where you went all wrong is where you tried to do the ##\exp(j n \omega t)## form, and your current posting still does not deal with that problem!
I guess what I am getting at is, does there exist a set of equations that works for every periodic function to find the Fourier coefficients? Or, do you have to modify your approach every time?
I hadn't been receiving much positive feedback, so I just wanted to take a step back first.
So, just to clarify, is the ##a_0## I calculated the DC component or is it the coefficient of the 1st harmonic? Looking at it again, I think it's the DC component. If ##a_0## is the dc component, I think I need to keep calculating coefficients until n=7. In other words, do I need to calculate ##a_n## up to n=6 or n=7 to obtain the coefficient of the 7th harmonic?
For determining the complex coefficients, is the following formula correct: ##c_n=\frac{1}{T_0}\int ^{\frac{T_0}{2}}_{\frac{-T_0}{2}}x(t)\mathrm{exp}(-j\omega nt)dt##
If so, do I need to find ##c_n## when n=1, -1, 3, -3, 5, -5, & 7 (assuming the even subscripts yield 0's) in order to find the coefficients up to the 7th harmonic?
Thank you for your time. I know it probably isn't easy being a helper on this forum.
Captain1024 said:
I guess what I am getting at is, does there exist a set of equations that works for every periodic function to find the Fourier coefficients? Or, do you have to modify your approach every time?I hadn't been receiving much positive feedback, so I just wanted to take a step back first.
Basically, you need to start with some standard formula for Fourier coefficients, either based on ##[-\pi, \pi]## or ##[0, 2 \pi]##, then do a change-of-variable to translate those into formulas for ##[A,B]##. So, if we start with
$$f(t) = \frac{1}{2} a_0 + \sum_{n=1}^{\infty} [ a_n \cos(n t) + b_n \sin(n t)],\\
a_n = \frac{1}{\pi} \int_0^{2 \pi} \cos(n t) f(t) \, dt, \; b_n = \frac{1}{\pi} \int_0^{2 \pi} \sin(n t) f(t) \, dt,
based on ##[0, 2 \pi]##, we are looking at trigonometric functions whose arguments go from ##0## to ##2 \pi n## for integer ##n##. On ##[A,B]## we want the arguments of our trigonometric functions to go from ##0## when ##t = A## to ##2 \pi n## when ##t = B##, so the argument is of the form ##2\pi n (t-A)/(B-A)## in the series and in the integrals that give the coefficients. This is just a straight change-of-variable problem.
I recommend that you do it once and file the results for future reference.
I now take back my statement that you calculated the trigonometric form coefficients correctly; looking at what you did, you made some puzzling blunders. I suggest you start again, carefully. Hint: you should get ##a_0 = 1## (so that the series starts off as ##(1/2)1 + \cdots = 1/2 + \cdots##), ##a_1 = 2/\pi##, ##a_2 = 0##, ##a_3 = -2/(3 \pi)##, etc.
Below, I show a plot of my series (up to n = 6) and of yours (up to n=6); mine is in blue and yours is in red. As you can see, the blue graph looks much closer to the function than does the red graph.
I'm finally making some progress on this:
Trig form:
##x(t)=a_0+\sum ^{\infty} _{n=1}a_ncos(2\pi ftn)+\sum ^{\infty}_{n=1}b_nsin(2\pi ftn)##, where n is the harmonic number.
Where ##a_0=\frac{1}{T}\int ^{\frac{t}{2}}_{\frac{-T}{2}}x(t)dt##. Simplifying, ##a_0=\frac{1}{T}\int ^{\frac{T}{4}}_{\frac{-T}{4}}x(t)dt=\frac{1}{4}[t]^1_{-1}=\frac{1}{4}*2,\ \therefore a_0=\frac{1}{2}##.
Where ##a_n=\frac{2}{T}\int ^{\frac{T}{2}}_{\frac{-T}{2}}cos(\frac{2\pi tn}{T})dt=\frac{2}{T}\int ^{\frac{T}{4}}_{\frac{-T}{4}}cos(\frac{2\pi tn}{T})dt=\frac{2}{T}[\frac{T}{2\pi n}sin(\frac{2\pi tn}{T})]^{\frac{T}{4}}_{\frac{-T}{4}}##
##=\frac{1}{\pi n}[sin(\frac{2\pi n\frac{T}{4}}{T})-sin(\frac{2\pi n\frac{-T}{4}}{T})]=\frac{1}{\pi n}[sin(\frac{\pi n}{2})-sin(\frac{-\pi n}{2})]=\frac{2}{\pi n}sin(\frac{\pi n}{2})##.
Then, ##a_1=\frac{2}{\pi}, a_2=0, a_3=\frac{-2}{3\pi}, a_4=0, a_5=\frac{2}{5\pi}, a_6=0, a_7=\frac{-2}{7\pi}##.
Graph:
Link: http://i.imgur.com/sTPtTlP.png
Exp form:
##x(t)=\sum ^{\infty}_{n=-\infty}c_nexp(j\omega _0tn)##
Where, ##c_0=\frac{1}{T}\int ^{\frac{t}{2}}_{\frac{-T}{2}}x(t)dt=a_0\ \therefore \ c_0=\frac{1}{2}##
##\mathrm{Where,}\ c_n=\frac{1}{T}\int ^{\frac{T}{2}}_{\frac{-T}{2}}x(t)exp(-j\omega _0tn)=\frac{1}{T}\int ^{\frac{T}{4}}_{\frac{-T}{4}}x(t)exp(-j\omega _0tn)=\frac{1}{T}[\frac{-1}{j\omega _0n}exp(-j\omega _0tn)]^{\frac{T}{4}}_{\frac{-T}{4}}=\frac{-1}{j\omega _0nT}[exp(-j\omega _0n\frac{T}{4})-exp(j\omega _0n\frac{T}{4})]=\frac{-1}{j\omega _0nT}(-2cos(\omega _0n\frac{T}{4}))=\frac{2cos(\frac{\pi n}{2})}{j2\pi n}##
Then, ##c_1=0, c_2=\frac{-1}{j2\pi}, c_3=0, c_4=\frac{1}{j4\pi}, c_5=0, c_6=\frac{-1}{j6\pi}, c_7=0##
Am I correct up to this point?
It was nice to check my trig form answer with the MATLAB graph. I believe the graph I have above is part of what he is looking for in part (2). The other part being a plot of the original rectangular pulse function, which is proving a little more difficult to accomplish in matlab. How do I plot the given function?
Next, I don't think I can check the exp form the same way. Part (3) asks for the magnitude spectrum plots up to n=7. I think he wants 3 plots; One for each non-zero ##c_n## coefficient. I poked around MATLAB help and couldn't find a straightforward way to accomplish this. How do I plot the magnitude spectrum plots?
Thanks.
Trig form:
Graph:
Exp form:
Thanks.
I do not have access to Matlab, so I use Maple instead. In Maple, if I want to plot two graphs ##y = f_1(x)## and ##y = f_2(x)## together on a common interval ##x \in [a,b]## I would just say "plot([f1(x),f2(x)], x=a..b, color = [red,blue])" to get ##f_1(x)## in red and ##f_2(x)## in blue; or I could leave out the "color" option and let Maple choose the two colors. Is there a Matlab-equivalent method?
I don't know about how Matlab would deal with your other questions.
BTW: for future reference, the USUAL way of writing the Fourier series, say on ##[0, 2\pi]##, is exactly as I wrote it in post #9. That means that the series has ##\frac{1}{2}a_0## as the constant term, with the formula for ##a_0## being the same as the formula for ##a_n## by putting ##n = 0##. I recommend that you stick with the standard convention, because if you use one that is different from everybody else's it is more difficult to check your work for errors.
  • · Replies 16 ·
  • · Replies 0 ·
