Fourier Series Question: Express q(t) as a Fourier Expansion
The discussion centers on expressing the charge q(t) of a capacitor as a Fourier series expansion, specifically for a saw-tooth wave with a period of 2π. The user initially attempted to derive the Fourier coefficients using open boundary conditions but encountered discrepancies with the book's answer. The correct Fourier series representation is confirmed to be q(t) = Q[1/2 - (4/π²) Σ (cos((2n-1)t)/(2n-1)²)], achieved by recognizing that only odd n contribute to the series due to the properties of cosine.
  • Understanding of Fourier series and expansions
  • Familiarity with trigonometric functions and their properties
  • Knowledge of capacitor charge dynamics
  • Proficiency in LaTeX for mathematical expressions
  • Study the derivation of Fourier series for different waveforms
  • Learn about the properties of even and odd functions in Fourier analysis
  • Explore applications of Fourier series in electrical engineering
  • Practice using LaTeX for complex mathematical expressions
Students and professionals in electrical engineering, physicists, and mathematicians interested in Fourier analysis and signal processing.
Nylex
I got this question out of a book, but I can't get the book's answer. Since I can't draw, I'll just describe the graph given. Express q(t) as a Fourier series expansion.
The charge q(t) on the plates of a capacitor at time t is shown as a saw-tooth wave with period [itex]2\pi[/itex] and its peak is at [itex]t = \pi[/itex], where q(t) = Q.
At first, I tried to use the expressions for open boundary conditions (as q(t) is 0 at t = 0 and t = 2 pi). I got stuck, so I started again, with
[tex]q(t) = \frac{a_{0}}{\sqrt{L}} + \sum_{n=1}^\infty a_{n} \left(\frac{2}{L}\right)^\frac{1}{2} \cos \frac{2\pi nt}{L} + \sum_{n=1}^\infty b_{n} \left(\frac{2}{L}\right)^\frac{1}{2} \sin \frac{2\pi nt}{L}[/tex]
where
[tex]a_{0} = \int_{0}^{L} \left(\frac{1}{L}\right)^\frac{1}{2} q(t) dt[/tex]
[tex]a_{n} = \int_{0}^{L} \left(\frac{2}{L}\right)^\frac{1}{2} \cos \frac{2\pi nt}{L} q(t) dt[/tex]
[tex]b_{n} = \int_{0}^{L} \left(\frac{2}{L}\right)^\frac{1}{2} \sin \frac{2\pi nt}{L} q(t) dt[/tex]
Now, since the saw-tooth is symmetric, there was no need to calculate [itex]b_{n}[/itex], since they'd have been 0 anyway.
I represented q(t) using top hat functions:
[tex]q(t) = \left[\theta(t) - \theta(t - \frac{L}{2})\right]\frac{2tQ}{L} + \left[\theta(t - \frac{L}{2}) - \theta(t - L)\right]\frac{2(L - t)Q}{L}[/tex]
Then I used that to calculate [itex]a_{0}[/tex] and [itex]a_{n}[/itex], using [itex]L = 2\pi[/itex]<br /> <br /> After pages of working out, I got:<br /> <br /> [tex]a_{0} = Q\pi \left(\frac{1}{2\pi}\right)^\frac{1}{2}[/tex]<br /> <br /> [tex]a_{n} = \left(\frac{1}{\pi}\right)^\frac{1}{2} \frac{Q}{\pi} \frac{2}{n^2} (\cos n\pi - 1)[/tex]<br /> <br /> So,<br /> <br /> [tex]q(t) = Q\left[\frac{1}{2} + \frac{2}{\pi^2} \sum_{n=1}^\infty \frac{\cos nt \cos (n\pi - 1)}{n^2}\right][/tex]<br /> <br /> The book's answer is [tex]q(t) = Q\left[\frac{1}{2} - \frac{4}{\pi^2} \sum_{n=1}^\infty \frac{\cos (2n -1)t}{(2n - 1)^2}\right][/tex]<br /> <br /> I don't know where I've gone wrong. I can't post all my working, as it's a lot and would take forever to LaTeX.[/itex]
Nylex said:
So,
[tex]q(t) = Q\left[\frac{1}{2} + \frac{2}{\pi^2} \sum_{n=1}^\infty \frac{\cos nt \cos (n\pi-1)}{n^2}\right][/tex]
Well, your results are equivalent :)) I'm poor at LaTeX, but I'll try to explain.
First, there is a typo in a final result (I suspect it is a typo), there should be
[tex]q(t) = Q\left[\frac{1}{2} + \frac{2}{\pi^2} \sum_{n=1}^\infty \frac{\cos nt (\cos (n\pi)-1)}{n^2}\right][/tex]
(notice the braces in second cos), but you got it right in a_n expression.
OK, now whenever n is even, expression under sumation is equal to 0 because [tex](\cos (n\pi)-1) = 0[/tex] for even values of n.
So, we have to sum only if n is odd, otherwise written as [tex]n = 2k-1[/tex], for k going from 1 to inf.
For odd numbers [tex](\cos (n\pi)-1) = -2[/tex]
If you put it all together you can write
[tex]\sum_{k=1}^\infty \frac{-2\cos (2k-1)t}{(2k-1)^2}\right][/tex]
you can take the "-2" out of summation, and then you get the book's answer.
Hope my explanation was clear,
Cheers
Cheers
Yay, thanks very much. Yes, I did make a typo with the brackets in my post.
Thanks again :D.
