Fourier transform and locality/uncertainty
The discussion revolves around the relationship between locality and uncertainty in Fourier pairs, specifically exploring the implications of the uncertainty principle on signal duration and bandwidth. Participants examine theoretical aspects, mathematical properties, and the conceptual understanding of these relationships.
  • One participant asks about the link between the uncertainty principle and the lower bound on the product of time duration and bandwidth, questioning whether the principle forbids signals with unlimited time and bandwidth.
  • Another participant provides examples of a sine wave and a delta function to illustrate the trade-off between locality and frequency spread, noting that one value being exactly known results in an infinite spread of the other.
  • Some participants express a desire for an intuitive explanation of why the uncertainty principle establishes a lower bound rather than an upper bound on uncertainties, suggesting that larger uncertainties can be achieved with less accurate equipment.
  • There is a discussion about whether the lower bound applies to uncertainties about bandwidth and duration or to the magnitudes of these quantities themselves.
  • One participant questions the relevance of physics in the discussion, emphasizing the mathematical properties of the integral transform involved.
  • Another participant clarifies that the original post's reference to locality suggests a connection to particle position, indicating a potential misunderstanding of the context.
Participants express differing views on the implications of the uncertainty principle, particularly regarding its bounds and the relationship between locality and signal properties. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the need for clarity regarding the definitions of terms like "locality," "bandwidth," and "duration," as well as the mathematical versus physical interpretations of the uncertainty principle.
bznm
Could you explain a bit about the relationship between locality and uncertainty in Fourier pairs?
Many pages talk about uncertainty principle stating that the precision at which we can measure time duration of signal cannot unlimitedly grow without affecting precision on bandwidth.
Many other pages talk about the lower bound on time duration and bandwidth product themselves, not uncertainties about them.
What's exactly the link between them?
Furthermore, does the uncertainty principle forbid signal with unlimited time and bandwidth? I am talking about effective duration and effective bandwidth.
It may be useful to look at two extreme examples.
First consider a simple sin wave. The wave extends through all space so there is no locality. The Fourier transform of a sin wave is a delta function, so we have exactly one frequency and hence exactly one value of momentum.
On the other hand, if we started with a delta function, then we have a particle localized at a single point. The Fourier transform of a delta function is a sin wave, so we have an infinite spread of frequencies and hence an infinite spread of momentum values.
thanks! however this example only justifies that one spread or the other has to be non infinite...
in particular I'd like to have a somehow intuitive explanation of the fact that uncertainty principle gives a lower bound and not an upper bound..
The point of these examples is to show that when one value is exactly known as a delta function, the other value consists of an infinite spread of values.
You are always allowed to have as large of an uncertainty as you want, just use less accurate equipment. There is no physical justification to have an upper-bound on the uncertainty of any measurement. What is surprising is that a lower bound exists and no matter how good your measurement device is, you can never exactly measure position and momentum simultaneously. This is a purely mathematical consequence of defining the position of a particle using a wave function.
If you're looking for a simple proof of the formula, check out this page http://www.phys.ufl.edu/courses/phy4604/fall13/uncertaintyproof.pdf
why is physics implied? aren't we talking about mathematical properties of an integral transform? this is something I can't understand.
Then, I still don't get if the lower bound is on uncertainties about bandwidth, duration or if it is about the magnitude itself of this quantities.
Because you posted this in the General physics sub-forum. Also when referencing locality in your original post, it sounds like you are referring to the position of a particle. If you are asking this from more of a signal analysis perspective, then you should post this in the mathematics sub-forums.
You're right, that was my fault.
@MODERATORS, please: could you move the question?
  • · Replies 17 ·
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 43 ·
