Fourier transform of differentials equation
36 replies · 7K views · last reply
should i test for e^-ax or x^5 or e^(x^2) or
[itex] y(x)=\int_{-\infty}^{\infty} e^{-a|x|}f(x-t)dt[/itex]
i'm sorry coz keep on asking.. but, i really don't know which one should i use to run the test.
You want to test to see if [itex]y(x)[/itex] converges for each of your two [itex]f(x)[/itex]'s. If the integral doesn't converge, then no solution exists.
so.. i need to test the equations below?
[itex] y(x)=\int_{-\infty}^{\infty} e^{-a|x|}f(x-t)^{5}dt[/itex]
and
[itex] y(x)=\int_{-\infty}^{\infty} e^{-a|x|}f(e^{(x-t)^{2}})dt[/itex]
correct?
by performing the improper integral test, when f(x) = x^5, the integral will converges
when f(x) = e^(x^2), the integral will diverges..
hence.. when f(x) = x^5, the is a solution, when f(x) = e^(x^2), there is no solution..
correct?
I just noticed that you have an error in your expression. Convolution tells you that [itex]y(x)=\frac{1}{2a}\int_{-\infty}^{\infty}f(x-t)e^{-a|t|}dt[/itex], not [itex]\frac{1}{2a}\int_{-\infty}^{\infty}f(x-t)e^{-a|x|}dt[/itex].
change it already.. thanks
the first part of the general solution should be c1(cos XXXX) + c1(sin XXXX) right?
just ignore the XXXX.. just want to know the pattern..
