Fourier transform of hyperbolic tangent
The discussion revolves around the Fourier transform of the hyperbolic tangent function, specifically the integral involving the function and its behavior under transformation. Participants explore various methods to compute this transform, including contour integration and properties of related functions.
  • One participant expresses difficulty in calculating the Fourier transform of the hyperbolic tangent function and seeks suggestions.
  • Another participant suggests that the integral may not converge as a classical Riemann integral but could exist as a generalized function.
  • It is proposed that the derivative of the hyperbolic tangent function, which is the hyperbolic secant squared, could be used to facilitate the calculation of the Fourier transform.
  • A participant shares a result from WolframAlpha for the Fourier transform of the hyperbolic tangent function, indicating a potential analytical solution.
  • One participant reports finding a result for the Fourier transform of the hyperbolic secant squared function using contour integration, suggesting a relationship to the hyperbolic tangent function's transform.
  • There is a discussion about the treatment of singularities in the Fourier transform, particularly at zero frequency.
  • A participant mentions that they ultimately found the Fourier transform of the error function, which was their original goal, and no longer needed the transform of the hyperbolic tangent function.
  • Another participant indicates that the discussion is helpful for their own needs related to the Fourier transform of a differential amplifier characteristic that resembles the hyperbolic tangent function.
Participants do not reach a consensus on the convergence of the integral or the exact form of the Fourier transform. Multiple competing views and methods are presented, and the discussion remains unresolved regarding the definitive analytical expression for the Fourier transform of the hyperbolic tangent function.
There are limitations regarding the assumptions about convergence and the definitions of the Fourier transform used by different participants. The treatment of singularities at specific points, such as zero frequency, is also noted as a point of contention.
This discussion may be useful for individuals interested in Fourier transforms, particularly in the context of hyperbolic functions, as well as those working on related applications in engineering or physics.
jjr
Hello
I am trying to determine the Fourier transform of the hyperbolic tangent function. I don't have a lot of experience with Fourier transforms and after searching for a bit I've come up empty handed on this specific issue.
So what I want to calculate is:
##\int\limits_{-\infty}^\infty e^{-it\omega}\text{tanh}(bt) dt##
where ##b## is some constant.
Using ##\text{tanh}(bt)=\frac{e^{bt}-e^{-bt}}{e^{bt}+e^{-bt}}## leads to a mess of exponential functions, and does not bring me closer to a solution. Perhaps there is some other way, using tricks specific to calculating Fourier transforms that could be helpful here?
Any suggestions are most appreciated
J
I don't think the integral converges.
Sorry, I should of course have added that running it through WolframAlpha returns
##\mathcal{F}_t[\text{tanh}(t)](\omega) = i\sqrt{\frac{\pi}{2}}\text{csch}\left(\frac{\pi\omega}{2}\right)##
which I'm hoping to obtain analytically
This is an interesting problem. The original integral does not exist as a classical Riemann integral, but the Fourier transform exists, at least as a generalized function (ie, in the same way that ##\mathcal{F}\left[ 1 \right](\omega) = 2\pi\delta(\omega)##, or ##\mathcal{F}\left[ sgn(t)\right](\omega)=2 \, \mathcal{P} \frac{1}{\omega}##, where sgn(t) = 1 for t>0 and -1 for t<0, and ##\mathcal{P}## refers to the principle part).
One way to proceed may be to use the fact that ##\frac{d}{dt}\tanh(t) = \text{sech}^2(t)##, so that
##i\omega\mathcal{F}\left[ \tanh(t)\right](\omega) = \mathcal{F}\left[ \text{sech}^2(t)\right](\omega)##. Now you have an integral, ##\mathcal{F}\left[ \text{sech}^2(t)\right](\omega)## that is nicely behaved as in improper Riemann integral, and you may be able apply contour integration or some other technique.
Note that in the above I have been assuming the definition ##\mathcal{F}[f(t)](\omega) = \int_{-\infty}^\infty dt\, e^{-i\omega t} \, f(t)##. I think Wolfram has the ##2\pi## in the exponent, so if you just ask for the Fourier transform the constants won't be the same. So while the result from Wolframalpha may have constants that are not quite right for your definition of the Fourier transform, qualitatively the result seems plausible. This is because ## \text{csch}(\omega)## qualitatively looks like ##\frac{1}{\omega}## (especially near zero, which is what matters when b is large), and as ##b\rightarrow \infty##, ##\tanh(b t)## seems to "converge" (in the sense of distributions) to ##sgn(t)##.
Jason
Update: using contour integration I find
##\mathcal{F}\left[ \text{sech}^2(t)\right](\omega) = \int_{-\infty}^\infty dt\, e^{-i\omega t}\, \text{sech}^2(t) = \pi \omega \, \text{csch}\left(\frac{\pi \omega}{2} \right)##
What do you get?
Jason
edit: by the way, I think (although I am not sure) that this means that the answer to your original problem is,
##\mathcal{F}\left[ \text{tanh}(t)\right](\omega) = -i \, \pi \, \mathcal{P}\, \text{csch}\left(\frac{\pi \omega}{2} \right)##.
If you aren't worried about specifying how to treat the singularity at ##\omega=0## then you can get rid of the principle part and use
##\mathcal{F}\left[ \text{tanh}(t)\right](\omega) = -i \, \pi \, \text{csch}\left(\frac{\pi \omega}{2} \right)##
What do you get?
Jason
I ended up going a different route. I was working with the ##\text{tanh}(t)## function because I needed something that closely resembles the error function ##\text{erf}(t)=\frac{1}{\sqrt{\pi}}\int_{-t}^t e^{-t'^2}dt'##, for which I initially couldn't find the F.T. I managed to calculate it after all, and so didn't need the F.T. of ##\text{tanh}(t)##.
Thanks for your help. Since this seems to be a rather unique question hopefully the thread can help someone else at some point.
J
Actually, this is helpful to me, as I need the FT of a differential amplifier characteristic, which is tanh(). Thank you for your postings!
Yet Another Grad Student
