Solving Fraction Function Homework: (x+1)/(x+6) >or= 0
  • Thread starter Thread starter shoook
    Fraction Function
To solve the inequality (x+1)/(x+6) ≥ 0, identify critical points where the numerator and denominator change signs, specifically at x = -1 and x = -6. Analyze the sign of the expression in three intervals: x < -6, -6 < x < -1, and x > -1. In the interval x < -6, the expression is positive; between -6 and -1, it is negative; and for x > -1, it is positive again. Include the endpoints x = -1 and x = -6 since the inequality is non-strict. The solution set is x ≤ -6 or x ≥ -1.
shoook
Solve: (x+1)/(x+6) >or= 0
Don't know where to even start.
List all of the x values where the numerator and denominator of the left hand side can change signs. Quick!
x=-1 x=-6 ?
Great! So if x<-6 what's the sign? If -6<x<-1, what's the sign? If x>-1, what's the sign? You only have three cases. Since it's >or=, you should think about x=-1 and -6 as well.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
