Free Falling powder in a vacuum
  • Context: Graduate
  • Thread starter Thread starter ravindrar
    Falling Powder Vacuum
The discussion revolves around an experiment involving the free fall of powder in a vacuum chamber. Participants explore the behavior of the powder as it is released from a conical hopper, examining the effects of vacuum conditions, electrostatic charges, and the design of the hopper on the scattering of the powder.
  • One participant describes an experiment where powder released in a vacuum chamber did not fall straight but scattered, prompting questions about the underlying physics.
  • Some participants propose that residual gas in the chamber might be sufficient to scatter the powder as it falls, despite the vacuum conditions.
  • Electrostatic effects are suggested as a possible reason for the scattering, with some participants noting that powders can accumulate charge and that this could influence their behavior during free fall.
  • Concerns are raised about the design of the conical hopper, with some arguing that the shape may induce turbulence and horizontal velocity components in the falling powder, contributing to scattering.
  • Suggestions are made to improve the vacuum conditions and to consider using UV light to enhance particle charging, although one participant notes they cannot sort the particles.
Participants express multiple competing views regarding the causes of the powder scattering, including vacuum quality, electrostatic effects, and hopper design. No consensus is reached on a single explanation.
Participants acknowledge limitations in vacuum quality and the potential for residual gas, as well as the complexity of powder behavior under different conditions. The discussion remains open to further exploration of these factors.
ravindrar
I made experiment on "Free Fall". I made a conical hopper of 15 liter volume and a vacuum chamber of , installed hopper upon vacuum chamber of 65 liter volume. Fixed a 2.5" gate valve to discharge powder in vacuum chamber. Connected both, hopper and vacuum chamber to vacuum pump (63 cum/ hr) and evacuated air to till pressure was <-759 mm HG, from both hopper and chamber. By opening the valve of the hopper dropped the powder in vacuum chamber.
As per Newtonian physics, free fall is any motion of a body where gravity is the only acceleration acting upon it. In the context of general relativity, where gravitation is reduced to a space-time curvature, a body in free fall has no force acting on it.
But the powder did not fall straight instead it scattered all over the vacuum chamber.
This is not my area of expertise, but two possibilities spring to mind immediately.
1. No matter how good your vacuum pump is and even if you leave it to run for a long enough time to compensate for out-gassing from the chamber walls, there will always be a residual level of gas in the chamber. Perhaps this is sufficient to scatter the powder as it falls.
2. Is there any possibility of a static charge on the powder and/or the chamber?
Your describe a pressure of about 1 Torr. At this pressure the molecular density if of the order of 10^18 molecules per cc. By the standards of vacuum physics this is still only a medium vacuum.
If the particle didn't fall vertically then I'd suspect some electrostatic effect. Powders are devils for picking up charge as they jostle together. Equal and opposite charges but different masses could, I suspect, cause an apparent spreading of the cloud of particles.
I'd go with 'static'. IIRC, 'fly' lunar dust proved a serious issue for the Apollo crews, spoiling sample box seals, abrading space-suits, getting into moving joints and totally contaminating LEM interior, causing breathing difficulties.
I agree that you need a better vacuum. Charging of the dust particles is definitely an issue and you might consider using this to sort particles by size. You could even put in a UV lamp to increase the particle charging.
Even with a perfect vacuum, I would suspect that the conical hopper is mostly to blame. The clump of powder will behave like a fluid as it falls. The particles near the edge of the hopper will attain an horizontal velocity component which will induce turbulence into the general mass. Even with a cylindrical hopper, the shear turbulence induced by the walls of the hopper would probably cause some scattering.
Thank you. I agree with you. Particularly when molecular density is 10^18. But have you seen Brian Cox's video. A large feather is falling straight though the surface area of area is very large.
Thank you, I can not sort particles. I will try UV as suggested. However I am also looking for any other solution to fill the powder without scattering.
Thanks for suggestion. Will think over it
  • · Replies 19 ·
  • · Replies 39 ·
18K
12K
