Frequency and phase relationship
The discussion clarifies the relationship between frequency and phase, emphasizing that frequency is not the time derivative of phase in the conventional sense. Instead, phase is defined as a parameter indicating the relative position of periodic waveforms, exemplified by the equation sin(2πft + θ), where θ represents phase. The conversation highlights the distinction between electrical engineering (EE) terminology and physics definitions, particularly in the context of modulation schemes like FM. It concludes that confusion arises from differing interpretations of "phase" across disciplines.
  • Understanding of periodic waveforms and their mathematical representation
  • Familiarity with the concepts of frequency and angular frequency
  • Knowledge of phase relationships in signal processing
  • Basic principles of modulation schemes, particularly Frequency Modulation (FM)
  • Study the mathematical representation of waveforms, focusing on sin(2πft + θ)
  • Explore the concept of group delay and its significance in signal processing
  • Learn about the differences between electrical engineering and physics terminology regarding phase
  • Investigate various modulation schemes, particularly the implications of phase in FM
Electrical engineers, signal processing specialists, and students studying the relationship between frequency and phase in waveforms will benefit from this discussion.
likephysics
Frequency is the time derivative of phase? But how?
Can someone explain?
No, it is not.
At least not if you use the normal meaning of "phase", in which case it is a parameter (usually a constant) which tells you the relative postion in time of two or more periodic waveforms
e.g. if you have
\sin (2\pi ft+\theta))
then \theta would be the phase. Note that it is only meaningfull to talk about phase when you are comparing waveforms; the "starting point" for a periodic function is arbitrary so there is no such thing as absolute phase.
Group delay is a derivative of phase with respect to angular frequency:
\tau_g = -\frac{d\phi}{d\omega}
OK, now I understand where you got that from.
This is why I was referring to the "normal meaning of phase" above.
People (meaning EEs) who work with modulations schemes (in this case FM) have a tendency to refer to the argument of the sine function as "phase" ; i.e "the phase" in this case would be \omega t+\theta and if you take the time derivative of this you obviously get \omega (which also happens to be the angular frequency, not the frequency).
So -unless I am missing something- this is just another case of confusion due to differences between EE and physics terminology.
The "definition" of phase I wrote above is certainly what you would find in a physics book.
  • · Replies 27 ·
  • · Replies 39 ·
12K
  • · Replies 30 ·
