Frequency components in a singnal.
9 replies · 10K views
Peon666
From a book:
"The waveform is distorted because of different amounts of attenuation and phase shift suffered by different frequency components of the signal"
Question:
If there are different frequency components in a single, how do the ratio channels operate on a single frequency. A channel, for example, operates on the frequency 101. How can this happen when the signal contains components of differing frequencies?
Thanks.
Peon666 said:
From a book:
Question:
Thanks.
The channel has some bandwidth, so that gives rise to different frequency components being in even a narrow-band signal.
The bandwidth of each US FM broadcast radio station is 200kHz, in the band from 87.8 MHz to 108.0 MHz.
http://en.wikipedia.org/wiki/FM_broadcasting
So, when we say ration station 106 (for example), we're talking about the Bandwidth. And Bandwidth means that this station/channel can be captured on all the frequencies in this band, right?
Another related question: When we say that a certain broadband/DSL connection has a bandwidth of say, 1 Mbps, what does that mean?
Thanks.
No, when you say FM radio station 98.5, that is the channel centered on 98.5MHz, with a bandwidth of 200kHz.
Thanks.
That means that the channel has enough bandwidth to support 1 million bits per second being transmitted through it (with an acceptably low bit error rate).
Thanks.
I bit confused about this. Does this mean that the channel is best transmitted at 98.5, but it can be transmitted, with a bit low quality, in the range of 200 kHz bandwidth?
Thanks.
Peon666 said:
Thanks.
Thanks.
No, the transmitted FM signal is centered at 98.5MHz, with signal components (due to the frequency modulation) that extend out +/- 100kHz above and below the center frequency. Check out this info on modulation, and its relation to channel bandwidth:
http://en.wikipedia.org/wiki/Modulation
Thanks a lot! It was really helpful! Taking first course in Analogue Communication. :)
