Friction bicycle homework Problem
4 replies · 17K views
MellowOne
[SOLVED] Friction Problem
A bicyclist can coast down a 5° hill at a constant 8.0 km/h. Assume the force of friction (air resistance) is proportional to the speed v so that Ffr = cv.
(a) Calculate the value of the constant c.
________ kg/s
(b) What is the average force that must be applied in order to descend the hill at 18 km/h? The mass of the cyclist plus bicycle is 85 kg.
________N
Sigma F = ma
Ffr = cv
First i converted my 8 km/hr into 2.22 m/s. Then i went into the parallel forces which are Ff and Fwx. The sum of their forces is equal to 0 because its acceleration is 0 so Ff is equal to Fwx and Fwx is equal to sin5 times mg which equlaed .854m. Then i set that equal to 2.22c because Ff also equal that. Now I'm stuck because I don't have mass. I tried writing out all units and canceling out so that on kg/s was left, but that didn't work out.
Any ideas?
You correctly found that cv = mg · sin 5º . Go ahead and use the mass given for the cyclist in part (b); I think it's not intended to be used there exclusively. The "resistance" coefficient (largely due to air drag) will depend on the mass of the rider and bicycle; a different rider would have a different value for c.
When using the mass given in part b, the answer came out to be approx 1 kg/s which wasn't correct. Is there something I missed or another way to approach this problem.
I used what you set up and found
c = (85 kg) · (9.81 m/sec^2) · (sin 5º) / (2.22 m/sec) .
Did you omit something?
Yeah, I must have forgotten something cause I did it again and I got the right answer. Thanks a lot.
