Friction Paradox: The Mystery of Constant Speed Motion
  • Thread starter Thread starter VVS2000
    Friction Paradox
The discussion centers on the friction paradox, where a block moves at constant speed with balanced external force and friction. It highlights the confusion about energy requirements when changing frames of reference. While the block appears at rest to an observer running alongside it, energy is still being expended to maintain motion relative to the ground. The key point is that energy is always required to overcome friction, regardless of the observer's frame of reference. Thus, changing perspective does not eliminate the need for energy input in the system.
VVS2000
I was reading this book on mechanics by derek raine and came up on something called friction paraddox.
Suppose a block is is moving with constant speed and the external force is balanced by friction. We know friction causes heat dissipation and the external force supplies some energy so as to keep the speed constant.suppose I run along with the block at same speed and with respect to me, block is in rest and there is no heat dissipation. So how come I have beem able to remove the need for supplying energy just by changing my frame of reference? Thanks in advance!
You haven't. In your frame of reference you are expending energy to move the floor under you.
Likes VVS2000
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
