How Do You Calculate Mass M1 in a Frictionless Incline Problem?
To calculate mass M1 in a frictionless incline problem, the forces acting on both masses M1 and M2 are analyzed using Newton's second law. The equations derived show that M1 can be expressed in terms of M2, gravitational acceleration, and the incline angle. A user initially calculated M1 incorrectly but found the correct answer by applying a different approach suggested by another participant. The discussion emphasizes understanding the coordinate system and acceleration directions for both masses. Ultimately, the collaborative effort led to a clearer understanding of the problem and the correct solution.
NoobeAtPhysics
M1 and M2 are two masses connected as shown. The pulley and the incline are frictionless. Find the mass M1, given that M2 (4.00 kg) accelerates downwards at 3.53 m/s2, and that θ = 32.0°.
F = m*a
Fk = u*N
Forces on m1
Fy = T - N - m1*g*sin(theta) = m1*a
Fx = N - m1*g*cos(theta) = 0
Forces on m2
Fy = m2*g*T = m2*a
Using equations above,
T = m2(g-a)
N = m1*g*cos(theta)
m2*(g-a) - m1*g*cos(theta)-m1*g*sin(theta) = m1*a
rearranging for m1
m1 =[m2*(g-a)]/[a+g(sin(theta) + cos(theta))]
Plugging in the correct values, I get 1.47kg for my answer which is... wrong :(
Thank you,
Noobe
I get
T - sin(θ)m1 g = m1 a
T - m2 g = -m2 a
Two equation with 2 unknowns. Does that help ?
Likes 1 person
Thank you Mentz that is very helpful! I get the right answer when I use your equations. Thank you again. =]Question:
T - m2 g = -m2 a
Why is it -m2 a and not just m2 a?
T - m2 g = -m2 a
Think about Newton's second law: F=ma
What is the acceleration of m1? What is the acceleration of m2?
consider gravity and the coordinate system Mentz114 has chosen when drawing free body diagrams for both blocks. That should answer your question.
Likes 1 person
Thank you very much guys, I understand it now! :), Physics is fun
  • · Replies 33 ·
