Frictionless, rotating circular hoop
The discussion focuses on a bead sliding on a frictionless circular hoop rotating at 4.00 rev/s. To find the angle of vertical equilibrium, the relationship between centripetal force and gravitational force is analyzed, using the equations F = m(v²/r) and the geometry of the system. It is questioned whether the bead can maintain the same elevation as the hoop's center, with hints suggesting that the hoop only provides radial force while gravity supplies tangential force. Additionally, the impact of reducing the rotation speed to 1.00 rev/s is considered, implying changes in the forces acting on the bead. Visual aids like diagrams are recommended to better understand the forces and motion involved.
courtrigrad
A small bead can slide without friction on a circular hoop that is in a vertical plane and has a radius of [i tex]0.100 m[/itex]. The hoop rotates at a constant rate of 4.00 \frac{rev}{s} about a vertical diameter. (a) Find the angle \theta at which the bead is in vertical equilibrium. (It has a radial acceleration toward the axis) (b) Is it possible for the bead to "ride" at the same elevation as the center of the hoop? (c) What will happen if the hoop rotates at 1.00 \frac{rev}{s}?
All I really know is that you have to find the velocity \frac{2\pi r}{T}. You have to use the equation F = m\frac{v^{2}}{r}. Is it possible to use the arc length formula s = r\theta?
Any help would be appreciated!
Thanks :smile:
HINT: The hoop can only provide the radial component of the centripetal force - i.e. gravity must supply the tangential component. :)
So the hoop is rotating about a vertical circle, while the bead is rotating in its own circle within the vertical circle? The direction of the acceleration is toward the center.
Thanks Tide for your hint
can someone please help me out
If you measure the angle from the vertical line connecting the center of the hoop to the lowest point on the hoop, then the radius of the "orbit" is R \sin \theta. This makes the component of centripetal force on the bead tangential to the hoop m \omega^2 R \sin \theta \cos \theta. The component of the gravitational force tangential to the hoop is m g\sin \theta.
Draw some pictures to verify the above and then proceed.
  • · Replies 44 ·
9K
  • · Replies 28 ·
  • · Replies 39 ·
15K
