I FTL communication via delayed choice measurement
Alex Torres
<Moderator's note: 2 threads merged as it is an identical topic.>
Given Kim's version of DCQE, let's say Bob in on Earth looking at d0, Alice is on Mars holding the prism that deflects the idler coming from (a) to d3 or (b) to d4. After the experiment run ends Bob should get clump at d0 without a feedback from Alice. In the actual experiment Bob receives each idler at d0, 8 nanoseconds before Alice
Given Kim's version of DCQE is it possible FTL communication by having Bob on Earth looking at d0, and Alice on Mars holding the prism that deflects the idler (a) to d4 and the idler(b) to d3 so by the time the experiment is done Bob would have a definite clump pattern at d0 without the need to receive any feedback from Alice. (To avoid noise from Bob to Alice we can use the same channel used by Victor, Alice and Bob in the Delayed choice entanglement swapping)
No, it's not. Bob sees the same thing on d0 regardless of Alice's choice. You need to split the measurements of d0 into two groups in order to see the interference or not, but in order to do the splitting you need Alice's measurement results.
Yes, know that will happen if you leave all 4 detectors at Alice. In Kim's papers you see a single band for all hits mixed in a single graph at d0, but if you see d3/d4 only there's a bell shaped pattern that even if you overlap for not cherry picking at them, due to symmetry you also get a bell shaped pattern at d0, assuming a setup with d3/d4 only.
Let me make just one correction. By Alice having only d3/d4 in place until the experiment is done, Bob don't even has to plot anything into a graph to see a clump at d0. Next day another run of the experiment starts at the same hour, but this time Alice has nothing in place so her twin idler gets lost in the space, after the experiment is done Bob should get fringes, since no measurenent was done.
That's not how it works. The signal photons whose corresponding idlers will interact with D3 or D4 if they are there contribute to the "clump" subset of the total detections at D0; the signal photons whose corresponding idlers would interact with D1 or D2 if they are there contribute to the "pattern" subset of the total detections at D0. Either way, the total pattern at D0 is the same.
(There are also practical problems separating any signal at D0 from background noise if any of D1-D4 are not providing input to the coincidence counter).
Likes Alex Torres
But... what pattern might you get at d0, by not detecting the idler at all and letting it just hit the wall?
You get the same pattern at D0 no matter what you do with the idler. Read @Strilanc's post in #3 again.
I understand, that completely applies as long as Alice is measuring both a particle and a wave in the same experiment run. My simple question is, what Bob will get at d0 if he just let all the idlers get absorbed at a piece of paper, since you are not making a definite measurement of anything at the idler, the most reasonable answer is that he gets a definite interference pattern at d0...but that's just my guess... don't know of any experiment done this way...
What Alice does has no impact on the result Bob gets.
This has been said multiple times now.
Ok, take Alice out of this...Bob is doing the experiment at home, he takes out all detectors and Beam splitters in the idlers path and put a piece of paper instead...my question is, what pattern, if any, will the signals photons form at d0 after all hits are recorded...
The same as with detectors, but now a sketch of the setup would help.
Alex Torres said:
Given Kim's version of DCQE is it possible FTL communication ...
In order to send a message, you have to change something under your control. In the case of entanglement, all you can do is observe the state. You cannot control the result of your observation (although you can choose what to observe).
It's fundamentally no different in this respect from the right shoe/left shoe scenario. If Alice receives a box with one shoe in it and Bob receives the other shoe, then they can observe what is in their box. That determines, but doesn't change, what's in the other box. Each has no control over what shoe they observe. And, if one of them replaces the shoe with an opposite shoe, that does not change the shoe the other one has.
Fundamentally, you cannot send a message by observation.
Likes Alex Torres
Again, let's take Alice out of this context ...Bob is doing the experiment at home, he takes out all detectors and Beam splitters in the idlers path and put a piece of paper instead...my simple question is, what pattern, if any, will the signals photons form at d0 after all hits are recorded... I am not asking here anything about FTL communication either!...
You received an answer:
Likes PeroK
In the proposal Bob is deciding himself no to measure position, my guess is that he should get a definite fringes pattern at d0, in Kim's papers it's pretty well explained why every single detector contributes to the single solid band at d0, but doesn't tell if all detectors are removed from the idlers path...
That experiment is easier said than done, because you need some way of picking the signal photons out from the much larger number of of incident photons that aren't part of signal/idler pairs. However, the downconverted photons do have a different frequency, so it should be possible in principle.
So what you're really asking is: Suppose we were to identify every detection at D0 that would have been included if we had our D1-D4 detectors and coincidence counter set up; what pattern do they form? Phrased that way, the answer should be clear: it's the sum of the four individual patterns.
Likes Alex Torres
Agree...then if we remove d1-d4 detectors the pattern at d0 will be________________.
Unchanged from if the detectors were there, so we can use the distributions in the paper to see what the pattern will be. Qualitatively, the rate-position graph is a hill with bumps on it, or you can visualize the pattern by overlapping the R01, R02, R03, and R04 illustrations from the wikipedia article.
sorry for no being specific, should read: if we remove d1-d4 detectors and replace them with a piece of paper then run the experiment again, when the experiment is done the pattern at d0 will be________________.
In other words, if you remove all BS's and detectors in the idlers path an just let it make its run toward a single piece of paper, after the experiment is done, the pattern at d0 will be ______________.
In all all questions of the form "If <some condition involving the idlers> and then we run the experiment again, the pattern formed by the signal photons at d0 will be _________?" we can fill in the blank with the same words: "What you get when you overlap the R01, R02, R03 and R04 illustrations from the wikipedia article; the rate-position graph is a hill with bumps".
(As a practical matter, we need some way of recognizing the signal photons; for every one that arrives at d0 we will get hundreds of thousands or millions of unrelated photons that will totally overwhelm the pattern formed by the signal photons. The idler detectors and the coincidence counter circuity take care of that when they're present so those are conditions under which it's easiest to actually observe the pattern. But once we've observed it, it's our answer no matter what we do with the idlers).
the proposal is that no condition is forced upon the idler, we let it fly freely all along until absorbed by a piece of paper, as someone stated before, the pattern at d0 will be the sum of the patterns provided by d1-d4, given they are in place, so it will still be a definite and distinctive pattern if compared with something else.
That's a condition (as would also be "we pay no attention to the idler" or "we have no idea what is done with the idler" or "the idler falls into a black hole" or ...).
Likes Alex Torres
yep.. you are right...so let me use another term: you are not measuring the idlers in anyways..still take into account that it just passed thru the double slit...
See also: "A Classical Delayed Choice Experiment" http://algassert.com/post/1720 , which makes it a bit clearer what the mistake you're making is:
Likes Alex Torres
Alex Torres said:
im just asking a question given a proposal
An you are getting the same correct answer over and over again. Do you expect the answer to change if you ask yet another time?
Likes weirdoguy
Believe me, it's not my intention to be redundant, but haven't get a definite answer yet, so will make this a final question like a poll, a yes or no ...will do it... Here is it: ...After the entangled photons are deflected by the Glan-Thompson prism and the one named the idler takes the longer path and gets absorbed at a piece of paper without being measured...once the experiment is done and given both the signal and the idler went thru the double slits as a single photon, and no measurement was made, will d0 show a definite difraction pattern?...yes or no...thanks!
We can't answer that question with a yes or no because it's based on a false premise - neither the signal nor the idler ever go through the double slit. They are created together in the BBO crystal after the pump photon has passed through the double slit and is down-converted.
(Another problem is is that you're asking about one photon, and of course one photon never yields any sort of pattern, just a single detection somewhere. I'm assuming that's just careless wording and you meant to say something along the lines of "a statistically significant number of signal photons have reached d0 and d0 has made a full sweep across its range of motion").
We can remove that false premise from your question and reword it as "Once the experiment is done and no measurement of the idlers was made, will d0 show a definite interference patttern?". Then, since whatever happens or doesn't happen to the idlers is completely irrelevant to the overall pattern of signal photons at d0, we can further simplify the question to "Once the experiment is done, will d0 show a definite interference pattern?" The answer to that question is "yes, and we've told you what that pattern looks like several times already".
Likes Alex Torres
  • #31
Then, a definite interference pattern at d0 can be distinguished from an overall pattern at d0 resulting from different outputs being overlapped. Am i correct?
  • #32
Quick answer: No.
Longer answer:
In one run of the experiment we accumulate a large number of position measurements, basically observations of the form "detector d0 detected a signal photon when it was at position x". We look at these and find a pattern: some areas get more detections than others. It's always the same pattern every time we run the experiment no matter what happens with the idlers, and that's all the information that we ever get from d0. There will never ever be but that one pattern at d0 (unless we change something else like the frequency of the pump laser, or the position and shape of the slits, or the characteristics of the BBO crystal).
Now suppose we take our large collection of position measurements and divide it into four groups. (We could put measurements 1, 5, 9, ... in the first group, 2, 6, 10, ... in the second group, 3, 7, 11, ... in the third group, and 4, 8, 12, ... in the fourth group. Or we could do the assignments randomly: for each measurement we generate a random number between 1 and 4 and put that measurement in that group. Or we could do something else). Then we look at the pattern for each group. Several things should be obvious:
- The total pattern will be the sum of the patterns for each group. It's nonsense to talk about the sum being somehow different from the total pattern (which is why the quick answer above is "no").
- The pattern for any single group doesn't have to look like the total pattern. For example, we could choose to put all the measurements in which x is less than .1 in one group; then we'll find that the pattern for that one group has a huge spike where the pattern for the other three groups has a huge trough, and neither the trough nor the spike appears in the pattern we actually measured. That doesn't mean that we've observed anything different; it's just an artifact of how we've manipulated our data.
There is one particularly interesting way of dividing our collection of position measurements into four groups. We are sitting around admiring the nice pattern we found at d0 when Alice walks up to us and suggests that we try putting this one, this one and this one into group one, then that one and that one into group two, and so forth. We're intrigued, so we ask her how she's choosing, and she explains that she's putting all the ones whose idler triggered d1 into one group, all the ones whose idler triggered d2 into another group, and so on. So we divide our collection of position measurements into four groups as Alice suggests, then we look at the pattern for each group in isolation... and we get something that looks like the patterns in Kim's paper, with interference fringes in groups 3 and 4 and not in groups 1 and 2.
Likes Alex Torres, Strilanc and Lord Crc
  • #33
Nugatory said:
In one one run of the experiment we accumulate a large number of position measurements, basically observations of the form "detector d0 detected a signal photon when it was at position x". We look at these and find a pattern: some areas get more detections than others. It's always the same pattern every time we run the experiment no matter what happens with the idlers, and that's all the information that we ever get from d0. There will never ever be but that one pattern at d0 (unless we change something else like the frequency of the pump laser, or the position and shape of the slits, or the characteristics of the BBO crystal).
Then we get a definite interference pattern for each experiment run under the conditions proposed.
But there's still something i don't get from the rest of your answer,... if we run Kim's version exactly as it is, the overall patterns at d0 is always the same, which happens to be a bell shaped graph, see Strilanc's comment above under "what Alice sees" column.
So we can summarize all the above for the sake of simplicity as follows:
Setup A: is exactly as Kim's description.
Setup B: the idlers path is cleared from BS's and detectors, and has a single piece of paper as a unique target, so no measurement is done.
Overall results at d0, (without sorting the hits)
Setup A: a bell shaped graph
Setup B: a definite interference pattern
  • #34
Or disclosing it in a more specific way. ...
The overall results at d0, (without sorting the hits) will show the following intensity across the screen:
Setup A: a single bell shaped pattern
  • #35
No, both setups produce the same single-hump pattern. Strilanc's picture is correct and I didn't do the addition of the patterns properly the first time around. If you look carefully at the R01 and R03 curves, you'll see that one has a peak where the other has a trough, so the peaks and troughs don't appear in the sum.
  • #36
But didn't say it wasn't correct, just said it applies as long as we run Setup A: Kim's set up as it is.
Just to make it sure i got your point...are you referring in this quote to the sum of the patterns at d1/2?
  • #37
This is a quote of what's actually described about hits from d1/d2 selected at d0..."One can get an idea of how this works by looking at the graphs of R01, R02, R03, and R04, and observing that the peaks of R01 line up with the troughs of R02"...R01 and R02 are the individual interference patterns we get from hits at d1 and d2, if they overlap, we get the single hump pattern at d0 described in Strilanc's comment under "what Alice sees" column as the erasure graph.
...But, the proposed Setup B assumes no detectors are in place for the idlers path, only d0 for the signal, ...so no detector is measuring position anywhere in the setup and no erasure is done either, ...then, wouldn't it be reasonable to ask: is there anything that could possibly preclude all signal photons from hitting d0 as a wave in a way that a definite interference pattern at d0 emerges?.... just asking
  • #38
Just a second thought...but first, thanks to all you guys for taking a slice out of you time and give such an useful insights toward this proposal... it's not mine by the way...saw it in the comments section about a DCQE video and found it quite interesting and enough convincing to be posted in a forum like this to get some feedbacks ...
...first thing noted...the fact that Kim's version needs 2 detectors to measure which way and another pair of detectors to measure which way erasure...forces Alice to go back to Bob in order to make sense out of "what she sees at the screen" for having the results overlapped. But then, the results are overlapped since 2 detectors are needed to measure which way and another pair to measure after erasure.
So this is kind of a loophole.
Let's say Bob just realized that, and thinks, the single-hump pattern Alice always get at the screen is a definite pattern after all if compared with something else...
Then he thinks in a radical way and decides to add a second experiment setup totally different to the one he has used so far and gives Alice a second screen to collect the hits from this second setup.
He thinks, to get a message across to Alice i need to find out the way to arrange this second setup in oder to obtain a pattern that just looks distinctively different from the single-hump pattern she always get from the first setup... so if the photons can travel all along to Alice as a wave then she might get a distinctive interference pattern at her screen and that will be a totally different pattern from the single hump pattern she has received so far.
So he decides to discard all detectors and BS's and replaces all that with a single piece of paper as the sole target for all the idlers photons he gets.
Here is the question...is he going to succeed to have a definite interference pattern at Alice's second screen?
  • #39
You might find this article interesting. The point was that it appears impossible to extract information in the manner you are describing, you need information that you can only get at sub/equal-light speeds.
https://arxiv.org/abs/1707.06995
Likes Alex Torres
  • #40
How many times do we have to say NO IT WON'T MAKE AN INTERFERENCE PATTERN before you'll actually hear the answer?
  • #41
Yep...also have seen others rising concerns because on the non communication theorem, but then found out it is conditioned to the use of quantum states as a medium to carry classical bit, there's an obvious reason why you can't use a probability distribution to send any coherent message at all...
  • #42
Come on dude, this is a discussion forum, ...just saying "No" isn't enough... All answers so far are related to why you can't get an interference pattern given Kim's version as it is...
...but, if the reason to have a double slit in the setup is to produce an interference pattern that can be projected or obtained somewhere in the setup, haven't seen an explanation so far about why it would be impossible to obtain that pattern given there's no measurement anywhere in the modified setup...
  • #43
Your question about "why it would be impossible..." is always going to be tough, as tough as answering why pigs don't fly.
But it might help if you knew that entangled particle pairs - such as used in the Kim et al experiment - do not usually produce interference patterns. See S290, figure 2. And yet the correlated sub-groups within the overall do, as Kim demonstrated.
https://pdfs.semanticscholar.org/3644/6f15507880c629e06391adf9d21aa6d76015.pdf
Likes nsaspook
  • #44
Please give a specific reference for "Kim's version as it is". I have seen no link to an actual paper in any of your posts.
  • #45
No, the reason to have a double slit in the setup is...to see what happens when you have a double slit in the setup. Whether it produces an interference pattern depends on the entire setup. A double slit can't magically make interference where none is possible.
All of the answers you have gotten in this thread amount to repeatedly pointing out to you that none of the changes you have suggested making in the setup, as compared to "Kim's version as it is", change anything about the original setup that affects whether interference is possible. So if you can't get interference in the original setup (which you can't, and you appear to realize that), you can't get interference in any of your modified setups.
  • #46
You can scroll up to one of Strilanc's comments above where it clearly explains, with nice graphs, why Alice will never see an interference pattern, given Kim's setup, there's also an acceptable description of the whole experiment in wikipedia...
https://en.m.wikipedia.org/wiki/Delayed_choice_quantum_eraser
  • #47
Thought it was demonstrated, the interference pattern at the screen disappears if a measuring device is placed to see which slit the photon went thru.
  • #48
Yes, that's an example of "whether it produces an interference pattern depends on the entire setup".
  • #49
... maybe our only option would be to ask Kim. Did he test the setup for interference pattern before inserting any detector in the idlers path? just to be sure there wasn't something physically destroying the interference pattern before the idlers hit the first pair of detectors d3/4?... otherwise, the presence of those detectors would be totally redundant...
  • #50
You're forgetting the role of the coincidence counter circuitry in this experiment. No signal photon will be recorded and counted towards the pattern unless its idler is detected by one of the D0-D4 detectors. So if you remove any of these detectors, you're just asking Bob to throw out some of the D0 detections, and any changes in the observed pattern are just the result of not counting all the points in the pattern.
Likes Alex Torres
