Is the Speed of Light Truly Constant for All Observers?
The discussion revolves around the constancy of the speed of light for all observers, particularly in the context of special relativity (SR). Participants explore the implications of this constancy, its empirical validation, and its theoretical foundations, raising questions about its counter-intuitive nature and its relationship to time dilation.
  • Some participants express confusion about why the speed of light is considered constant, questioning whether it has been empirically proven or if it is merely accepted as dogma.
  • One participant presents a thought experiment involving a moving train and a flashlight to illustrate the implications of light's speed being constant, noting the difference in perceived distances traveled by observers in different frames of reference.
  • Another participant acknowledges that if the speed of light is constant, then time dilation must also occur, suggesting a link between these concepts.
  • There is a query about whether the constancy of light speed can be theoretically deduced or if it is solely based on empirical evidence, highlighting the difficulty some have in grasping this concept.
  • One participant discusses the dual nature of light as both a particle and a wave, referencing the double slit experiment and suggesting that the laws of physics apply uniformly across all frames of reference.
  • Another participant introduces the idea that the speed of light might be viewed as a universal speed limit, proposing that if such a limit exists, all observers must agree on its value.
  • There is mention of how classical mechanics would treat the speed of a thrown rock differently than the speed of light, but relativity modifies this understanding, leading to a more complex relationship between speeds in different frames.
Participants generally express uncertainty and curiosity about the constancy of the speed of light, with no consensus reached on its theoretical justification or implications. Multiple competing views and interpretations remain present throughout the discussion.
Participants highlight the counter-intuitive nature of the speed of light's constancy and its implications for understanding time dilation and the behavior of light as both a particle and a wave. The discussion reflects a range of perspectives on the empirical versus theoretical foundations of this concept.
kbaumen
I've recently read a short intro to SR and am quite curious to learn more but there are some things that bother me. One such issue is the fundamental speed of light (or is it properly 'velocity' even for light? English is not my mother tongue). I understand that time dilation would be impossible without the speed of light being constant to any observer irrespective of the observer's movement in reference to the light source but why is it constant? For me it seems sort of counter-intuitive. Has it been proven empirically? Or is it just a dogma?
Here's an example that got me thinking: Suppose you're in a train (that's moving in reference to Earth) with a flashlight in your hand and a mirror on ceiling above you. You turn on the flashlight, put it on the floor and direct it to the mirror. Now the light beam goes up to the mirror and comes down to the floor. You know the distance the light beam has traveled (2 times the height of the carriage you're in) and so you can calculate the time (because you know c) it took for the beam to be reflected on the floor. Now suppose an observer, from outside the train, standing on the ground, is watching. If the train is moving with a constant velocity, than the observer sees the light beam forming two sides of an isosceles triangle, hence, traveling a longer distance than observed by the person in the train and taking more time to do so. This is true, if the speed of light is constant to any observer.
So, why is it constant (or why it is widely accepted that it is constant)?
Your example does indeed show that if the speed of light is constant then there must be time dilation.
For experimental results to confirm that the speed of light really is constant, follow the link within the "Sticky:[/color] FAQ: Experimental Basis of Special Relativity" at the top of this Special & General Relativity forum, and in particular look at sections 3.1, 3.3 and 3.4.
Thanks for the input. But is there any way to theoretically (by some deduction or using other information as a basis) prove that c=const? Or it has just been proved empirically? I'm curious because this is something that's hard to grasp, at least for me. The constancy of c seems a bit counter-intuitive. If it is so, can light even be defined as a particle (photon)? Because then it should move just as any rigid body, shouldn't it? If a I throw a rock, then it's velocity is relative, it differs if you change the frame of reference, however the speed of light is absolute. All this is a bit confusing for me, though it raises curiosity.
The thing about light is that it acts as both a particle and a wave, it can have both properties... Look into the double slit experiment, it gives insight into just how much of a weird phenomenon light is...
Personally I think it speaks for it's self. If no matter what constant speed you're traveling at, the laws of physics are exactly the same in all frames of reference (this can and has been tested to a certain degree), those rules must also apply to light somehow. I believe Maxwell said that you can't have static light, meaning that it's not possible, in any frame of reference, to see a beam of light at rest beside you. It was with this theory Einstein came to the realisation that in order for this to be possible, time must adjust it's self so light can fly past you accordingly (keeping the laws of physics the same in all frames of reference).
Rocks and photons don't really behave differently. If you are traveling at 30 mph in a car and you throw a rock forward at 10 mph relative to the car, pre-relativistic Newtonian theory says that the rock goes at (30+10) mph relative to the ground. But relativity says the rock goes slightly slower at
(30 + 10) / (1 + 30×10/c2) mph​
relative to the ground. This formula applies to everything, rocks and photons. If you make one of the speeds c, you get an answer of c. (Of course that doesn't prove anything, as I haven't told you where my formula came from.)
One way of thinking about it is that c isn't so much the speed of light, it's the universal speed limit (and light just goes as fast as it can without breaking the limit). Either there is or there isn't a universal speed limit, and if you accept the principle of relativity that all inertial observers have equal status, then if the limit is finite then everyone has to agree on its value. Only experiment can tell us whether the limit is finite or infinite.
If you're in a moving boat and drop a stone into the water, the waves move radially away from the point where the stone contacts the water. You move away from that point, but the waves move at a constant speed relative to the water, and independently of your boat.
With material objects, the projected object acquires the speed of the parent object, but photons do not.
From the perspective of the person on the train, if you remove all his horizontal motion, which he does not detect by internal measurement, you are left with only vertical motion. Time dilation prevents his detection of a longer transit time for light, i.e. his observations are the same as if he is not moving.
The short answer is that it has just been proved empirically.
The long(er) answer is:
1) The value of a fundamental constant is always only determined empirically. If it could be determined theoretically then it would not be fundamental.
2) Only dimensionless universal constants are ever considered fundamental. The value of any dimensionful universal constant is an artifact of the system of units.
Thank you all for the answers.
  • · Replies 24 ·
  • · Replies 38 ·
  • · Replies 93 ·
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 26 ·
